    Default Interesting pipe fitting
    I had not seen one of these fittings before.
    Default Re: Interesting pipe fitting
    I have seen one of those before, once or twice. That is old school when plumbing was more that gluing and crimping stuff together. Back when Craftmanship that no one saw but the plumber who had pride in his work meant something.
    Aug 2011
    Pretty cool. Looks like age may have caught up to it.
    Yep, pretty cool! You are right about getting to the end of it's life. There were lots of heavy rust blisters, copper/galvanized connections, and a few leaks too.
    Jan 2011
    Guelph,Ontario
    Time to replace that mess.
    Osceola, AR
    Crossover fitting? That is all I ever heard those called. Few and far between, only see these a handful of times each year...
    Alton Darty
    ATN Services, LLC
    www.arinspections.com
    Nov 2007
    For some reason the picture is not showing for me.
    But here is something I bet most of you has not run into. This is a glass float ball for a ballcock.
    Chico,Ca
    Quote Originally Posted by Ron Hasil View Post
    Only ones I remember are copper, thanks for sharing.
    Utah
    That is very rare, and very cool. I agree with Jim Lutrall's comment, old school craftsmanship.
    Since you answered with a question mark, I'll confirm.
    simply "crossover" or as "crossover fitting", is correct; as is, and more commonly WAS "cross-over" fitting, coupling, bend, etc. or "cross over" fitting, etc. Not to be confused with a cross (four-way) or a cross or cross-over connection.
    Here is how the web-based version of the McGraw-Hill Dictionary of Architecture & Construction hosted by "answers.com" defines it for you:
    crossover
    2. A pipe fitting shapped like the letter "U" with the ends turned outward; used where one pipe crosses another in the same plane; also called a crossover fitting.
    clickable link for reference: Architecture and Construction: cross grain to crotchet from Answers.com
    An expansion U bend or double offset expansion U bend or double-offset U-bend can accomplish similar in slightly differing manner.
