    Default soot? on radon fan discharge
    Black soot, or something, at joints in radon system discharge. Previous motor burned up?
    Default Re: soot? on radon fan discharge
    Having technical difficulties. If you see a fireplace photo with this thread, ignore it. I can't seem to get rid of it.
    I thought that radon vent piping had to be permanently sealed at joints.
    Knowing very little about radon and even less about radon mitigation ... I can only ask the obvious ...
    1) Is rain downspout material suitable for radon discharge duct?
    2) Shouldn't radon discharge duct have the joints reversed from those shown in the photos? One would think that it would not be desirable to allow the radon to escape at each joint as the discharge pipe passed by building openings or even siding which is not sealed.
    Just some questions from an inquiring mind.
    Nov 2010
    CO
    I've seen Radon discharge pipe in a much larger sized downspout. It looks better than the 4" round pipe in my opinion. The joints should be sealed.
    Jeff
    Quote Originally Posted by Jeff Langhorn View Post
    Jeff
    Shouldn't the joints be reversed form those shown?
    In addition to sealing the joints, reversing the joints from that shown would create less leakage and would not allow water to run down the exterior of the duct/pipe and into the joints, where the water then runs down the inside of the duct/pipe and to the fan, where I doubt the water does much good when it gets into bearings, motor windings, blower wheels, etc.
    Or am I wrong in that thinking? Would you pour water down into the blower fan of a furnace or air handler? I would not - unless I was testing it to see what damage it would do.
    Is there a furnace in the same room as the radon unit? If so, I would suspect the whole installation is kaka.
    Nov 2010
    CO
    I agree Jerry, joints should be reversed and sealed. The fans are designed to handle some
    water. Some systems have a water bypass tube. Most Radon discharge pipes do not have a cap on the top.
    Jeff
    Richard Clemons's Avatar
    Richard Clemons Guest
    Radon PFE (Pressure Field Extension) should schedule 40 or greater pvc or radon approved insulated type guttering. This is not approved guttering. The seams are not sealed and create resistant to flow. This should be replaced with proper PFE; cracks in the floor should be sealed and furnace check for back draft situation. This is why IL require license and CEU's to get and maintain radon license. It's costly and dangerous if improperly done.
    Nov 2009
    Winston-Salem, NC
    Radon is only one soil gas that gets discharged from the end of the pipe. I have seen many blackened areas in Radon treatments. Moisture also is discharged and causes discoloration. I agree that the downspouts are below approved quaility.
