    Default Water Heater Knocking When Toilet Flushed
    A one bathroom ranch on a slab. This knocking sounds like it is coming from the water heater and only happens when I flush the toilet, not when I run other fixtures.
    https://www.youtube.com/v/WPntL4XrPBI
    Mike Lamb
    Inspection Connection, Inc.
    Default Re: Water Heater Knocking When Toilet Flushed
    Its likely a bad valve on the fill mechanism of the toilet. The diaphragm could be resonating due to water pressure, thus the noise.
    Did you try closing down the shut off valve to see if it affected the noise.
    Darrel Hood's Avatar
    Darrel Hood Guest
    This description also raises the possibility that the toilet is using hot water. If so, there is an opportunity to save a little money.
    New York
    Quote Originally Posted by Mike Lamb View Post
    Change your diet.
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    A hot water feed to the toilet makes sense. I never felt the tank to see.
    Mike Lamb
    Jan 2009
    San Antonio, TX
    I've come across this noise when the water shut off valve is not opened competely. Also some homes don't have water hammer chambers.
    A gentleman at The Inspectors Journal suggested that it is likely the ball in the WH heat trap knocking around when there is a slow water feed from the WH tank to the toilet.
    Mike Lamb
    Jan 2009
    San Antonio, TX
    Down here in the south we plumb the toilet with the cold water supply. Is there a reason to run a hot water pipe to a toilet?
    Quote Originally Posted by Ray Babcock View Post
    It's not common but it can stop toilet sweat and I have been tempted to do it to a bathroom at a summer home I have in Michigan. The condensation can be a real mess.
    Mike Lamb
    It would be easier to switch the toilet out for a new one with a lined tank. Why pay to heat water to stop sweating?
