Results 1 to 2 of 2
    Jan 2009
    Taylor, TX
    Default Disconnect for electric central heat unit
    Should a central heat unit with breakers installed in the side of the unit have a separate disconnect box independent of the unit?
    Default Re: Disconnect for electric central heat unit
    Yes, it 'should' have, but it is 'not required' to have, a separate disconnect.
