Thread: why here?
    Default why here?
    I've never seen a AAV in an attic like this. Is this allowed here. I think it was installed to vent a 1/2 bath which was installed at the 1st floor below this corner. Two story house.
    Default Re: why here?
    I don't see a picture, but as long as the AAV is above the insulation it's allowed.
    Aug 2011
    Yes.
    I have to add some more letters for the message to post.
    .. but as long as the AAV is above the insulation it's allowed.
    At least 6" above the insulation.
    Jul 2010
    Wisconsin
    Some of them have a cover when in attics that can get real cold or hot. Studor is allowed in areas from -40 to +150 degrees Fahrenheit and with a cover above or below those temps, and can go outside. The Sure Vent is only used indoors, and in the -40 to +150 degree range. And, the AHJ might have stricter requirements.
    Thanks guys!
