Thread: Just a tip!
    Default Just a tip!
    With summer here A/C inspections are back in the spotlight. Just a tip for anyone who doesn't know, a good indication of the condition of the outdoor coil is the direction of air flow at the fan. If it is horizontal the coil is restricted by dirt or proximity to walls or bushes. I use a piece of surveyors tape to illustrate the condition in the report. Hope this helps someone.
    Default Re: Just a tip!
    I just hold my hand over it - blowing hot air up is the right direction.
    Blowing cool air up and it is not working.
    Not blowing air up yet fan is running - not working right (fan may be wrong type for the motor direction.
    What brought this to mind was that I have found 3 units with air flow problems in the last three days. Two were tucked in a corner of a house with a wood fence on the third side. When both were running at the same time the tape almost went down into the fan blade. The one I have pictured is just dirty coils. The surveyors tape helps to confirm to the seller that something is wrong, as it is sometimes very hard to see that the fins are clogged.
    Vern, I like your tip. We may be able to tell with our hand, but I think the tape is a good way to take a picture you can include in the report that shows the customer that things are not right. Pictures always seem to help.
    Feb 2013
    nj
    Don't assume when it comes to refridgeration equipment. Some outdoor compressors will have variable speed condensor fans or may be equiped with a low ambient fan control kit which will shut down a condensor fan in order to increase head pressure in the system https://opi.emersonclimate.com/CPID/...AEB/ae1234.pdf
    Bill Kace
    Nationally certified Air Balance Technician
    Quote Originally Posted by BillKace View Post
    Bill Kace
    Low or Hi speed, the air will flow up not sideways with a clean unobstructed coil.
    Quote Originally Posted by Charles Wilson View Post
    Well ... you could tie a small parachute to Mr. Bill and let a rope (string) hang down where horrified-expression Gumby is holding Mr. Bill from blowing away in the upblast from the super-hyper-turbo-'weightlessness effect creator machine' below ... just sayin' ...
    I'm not ignoring you Jerry, I'm hunting through the grand kids toys
    Aug 2011
    Nice tip......
