Results 1 to 11 of 11
    JoeVSmith's Avatar
    JoeVSmith Guest
    Default Outlet spacing along glass wall?
    What are the requirements for outlets along a wall that is floor to ceiling glass(residential). I know the 6'/12' rule for wall but am not sure how this applies to glass walls.
    Thanks Joe
    Default Re: Outlet spacing along glass wall?
    Quote Originally Posted by JoeVSmith View Post
    Thanks Joe
    You need to ask the AHJ in your specific area as to what they want. What is written and what the real person might want to see can be two different things.... Best to get it from the horses mouth!
    JoeVSmith's Avatar
    JoeVSmith Guest
    Thanks will do.
    What Scott said, but a wall is a wall same rules apply. You may need a floor receptacle outlet if putting it in the wall will not work.
    My experience is that I see floor outlets. To build a wall that is glass I would put in floor outlets. Just makes it nicer if you need an outlet, if nothing else.
    Alain Charron's Avatar
    Alain Charron Guest
    Just going from memory from my electrical course, the rule does not apply where there are windows... at least here in Ontario. A receptacle is required every 12 feet of wall, excluding under windows.
    Like I said, going from memory only... I might be wrong.
    Quote Originally Posted by Alain Charron View Post
    Well ... he does have "ca" as his location ... but is that for Canada or for California?
    The NEC requires that spacing at walls, if the glass is fixed in place then receptacles would be required, but could be floor receptacles. If the glass is operable, like a sliding glass door, then no receptacle would be required.
    Alain Charron Guest
    That is ca for Canada... I did mention that I was from Ontario...
    May 2010
    No. San Diego Co., CA
    Ontario, San Bernardino Co, California
    Founded 1891, 50 sq. miles, population 166,000, about 35 miles east of downtown Los Angeles.
    Oct 2011
    california
    Floor outlets to be counted in the calcs for wall spacing must be within 18 inches of the wall
    Oct 2009
    michigan
    Just an additional note: The fixed portion (non-sliding pane) of a sliding door or door wall is also 'wall space' to be included in the 6' - 12' & 2' rule.
Tags for this Thread
