Results 1 to 1 of 1
Thread: Circulating Pump for DHW
06-14-2013, 01:52 PM #1
This was a different type of install than I normally see. The pump is installed on the outgoing hot water line, with no return line other than the cold water input. My concern is that the pump is just as likely to push hot water back through the main as it is to push it back into the tank. There is no back flow check valve on the main water supply to the house. Any thoughts on the pump installation?
Similar Threads:Jim Robinson
