Thread: Marco Manuel
    Jun 2013
    CALIFORINA
    Default Marco Manuel
    The firebox tag Says "Model # 792781" I havent been able to locate any info at all on the system
    Is this a correct model number
    New York
    Default Re: Marco Manuel
    Marco Manufacturing is listed under the Lynwood Fireplaces & Accessories Retail category and is located in 2520 Industry Way, Lynwood, CA. It can be reached at phone number (323)564-3201.
    CPSC, Marco Alert Consumers to Gas Fireplace Recall Due to Fire Hazard
    WASHINGTON, D.C. - In cooperation with the U.S. Consumer Product Safety Commission (CPSC), Marco Manufacturing Inc., of Lynwood, Calif., re-emphasized the recall of more than 22,000 gas decorative fireplaces to repair their vent systems. If the interior vent pipe separates from its connection to the exterior wall of the house, hot exhaust gases can start a fire inside the wall.
    Marco and CPSC are aware of 22 fires involving these fireplaces. Several of these fires caused extensive damage. No injuries have been reported.
    The Marco gas fireplaces subject to this recall have a sealed glass-front panel and vent systems that exit the house through the side wall. The fireplaces can be identified by a six or seven digit model number starting with 794 or 797. These model numbers can be found on a label inside the unit's lower grill door. Most of the fireplaces have model designations that include the letters, "CCT." Older models have the designation "MGC36DV." The model designation can be found on the owner's manual.
    Gas appliance, and hearth and fireplace distributors and dealers sold these fireplaces from February 1993 through November 1997 for about $1,000, and the separate vent system for about $140. Most of these fireplaces were installed during new home construction.
    Marco already has repaired about 9,000 fireplace vent systems since July 1998. All other owners need to stop using these recalled fireplaces immediately. Marco will arrange for free repair of recalled fireplaces. For additional information, assistance in determining if you have a recalled fireplace or to arrange for a free repair, consumers should call Lennox, which bought out Marco, at (800) 655-2008.
    Earlier this year, Marco agreed to notify all consumers who have these recalled fireplaces and make the repairs. However, this alert is being issued because not all consumers have been notified by the company about the fire hazard and repairs have not been completed.
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    Jun 2013
    CALIFORINA
    [QUOTE=Steven Turetsky;228065]Marco Manufacturing is listed under the Lynwood Fireplaces & Accessories Retail category and is located in 2520 Industry Way, Lynwood, CA. It can be reached at phone number (323)564-3201.
    Thanks Steve
    This is a woodburning fireplace. That recall was for a gas fireplace. When shooting rating plates, take your flash off and use indirect light. It takes practice but you'll record the data you need. Here, the most important data was washed out by the flash. Also, take more than one pic. Digital film is cheap.
    Most Marco woodburners were called their "Builder", "Classic" or "Architects" series. The first two were available in 36 and 41" openings while the Architect's was I believe a 46".
    Marco has been out of business for over 10 yrs now so good luck on finding info. or support.
    HTH
    Jun 2013
    CALIFORINA
    Thanks for your response Steve
    [QUOTE=mike flynn;228071]
    Thanks Steve
