Gast 1532 Pump w/flow valve
The Gast 1532 High Volume Sampling Pump is both durable
and economical. Its rugged construction and low maintenance
has made it one of the most popular sampling pumps on the
market! With the Gast 1532 producing free flow rate of over
45LPM, users will find that with a supplied locking flow valve,
air flow can be sufficiently controlled at rates from 2LPM -
35LPM. The Gast 1532 utilizes Rotary Vane cores to achieve
vacuum. The 1532 pump has an internal muffler chamber and
moisture containment system eliminating the need for the
Glass Jar system that was found on the Gast 1531 models.
This Pump has been redesigned to offer up to 70% Noise Reduction
Heavy Duty Case w/foam inserts
Filter Media Impaction Sampler
Telescopic Sampling Stand
Vinyl Tubing
$329
email just_go_for_it@yahoo.com for detailsMold Testing Equipment.jpgCase.jpg
