Results 1 to 2 of 2
Thread: Multi-Quotes
    Jul 2010
    Wisconsin
    Default Multi-Quotes
    How do you do the multi-quotes where there is box with the original quote followed by an answer then another quote in a box followed by another answer and etc? Usually it is someone responding to two, or more, other people with each of their quotes in a separate box. Are you cutting and pasting everything, or is there an easier way? Not sure how the "Multi-Quote This Message" feature works, when I check it nothing seems to happen other than it shows it's checked and the post reply looks the same.
    Also, do you guys remember the link code or use another method to create the "Click Here" link?
    Capistrano Beach, CA
    Default Re: Multi-Quotes
    Hi Mike,
    On the bottom right of each individual post that you would like to quote click the "Multi quote icon". When you have clicked all the post you want to quote then go to the bottom of the thread and click "Reply". You will then have all the quoted posts. You can now go in and edit each one to fit your needs.
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
