Results 1 to 13 of 13
    Aug 2009
    Raleigh
    Default Missing gusset plates?
    This town home was built in 2003 and at the roof ridge, there are no gusset plates. Collar ties are present on all but one area. It appears to me that the plates are missing. While not impossible, seems strange that this defect made it through various inspections/contractors. What do you think?
    Default Re: Missing gusset plates?
    Quote Originally Posted by Randall Clark View Post
    What do you think?
    Looks like Engineered Truss System may or may not be a problem ( check the drawings. )
    Lansdale, PA
    It appears to be either a modular/manufactured house built in two halves, or two piece trusses. Either way, the plans should spell out how the trusses should be joined. I suspect they would call for plywood or OSB gusset plates.
    First picture (Pidge/peak) are not factory-cut ends.
    Lansdale, PA
    I took another look at the photos. I noticed that the trusses on the right appear to be a different design than those on the left. That is not necessarily a problem, but the way the horizontal 2x6s (these are not collar ties) connect the the trusses appears to be wrong. They would probably be compression member and at the left side they connect below the joint. This is generally wrong. Also, it would be likely that the nailed connections would be inadequate. Appears to be a case of someone not following the truss installation drawings. The only way to figure that out is to get the installation drawings of have an engineer analyze the truss design and specify a repair.
    Chicago
    What drawings?
    Corey
    Quote Originally Posted by Corey Friedman View Post
    What drawings?
    Corey
    Each Engineered Truss Company ( look on the truss ) will have a set of drawings for their manufactured truss systems.
    Engineered Roof Trusses
    Chicago
    Hi Billy,
    My comment was actually sarcastic (sorry). I am quite familar with truss drawings.
    This was not a new construction inspection. So, what drawings? The homeowner would not likely have any truss drawings, blueprints or anything else. Additionally, checking drawings is way beyond a regular home inspection.
    Corey
    Hi Billy,
    Corey
    Yes beyond the Scope of Regular HI, (Report what you see at that time.)
    *drawings would be essential to defend yourself / client at a later date.
    Sep 2007
    Fredericksburg, VA
    The peak cuts are definitely not factory made. I bet the bottom stringers were cut too. Collar ties on trusses? No way. Looks like left overs cut to fit another job. Definitely requires SE review.
    Stu, Fredericksburg VA
    Looks like it was planned to have a ridge board installed on site on those particular trusses.
    Lansdale, PA
    A ridge board would not be the answer. Structurally it looks like the only way that those trusses would be ok as installed is if there were bearing walls below the vertical webs, and that seems unlikely. I had a thought that maybe someone modified some trusses designed with a steep pitch and cut out the center vertical web and parts of the top chords.
    It would not nice if the OP has any more photos or more details regarding the house. Otherwise, we are all just guessing. Regardless, from a home inspection standpoint, this is one where it is clear that a home inspector cannot tell what they did wrong, but should be able to tell that this certainly needs further evaluation.
    Jan 2009
    San Antonio, TX
    It's a good chance that the trusses ordered were the wrong size so they modified them. Note the collar ties that don't have gusset plates and the ridge that was roughly sawn and toe nailed at the top. Modifying trusses without an engineer or architect signing off on the changes is just wrong.
