Results 1 to 2 of 2
    brianmiller's Avatar
    brianmiller Guest
    Default Electrical cable routing
    Two questions:
    1) would the practically 90 degree bends be considered "excessive"?
    2) would you be concerned about the decking adjacent to the cables. I was thinking if there was structural movement the cables could be pinched by the decking, or am I overthinking again. Note: The decking is locked into place (nailed down), and is within 6ft of the attic access opening.
    Oct 2008
    Tulsa, OK
    Default Re: Electrical cable routing
    Quote Originally Posted by brianmiller View Post
    Two questions:
    1) would the practically 90 degree bends be considered "excessive"? Yes, These bends should not exceed 5 times the diameter or thickness of this cable.. This cable may have all had the insulation damaged by the 90 degree bends.
    I would not be concerned..
