    Al Roden's Avatar
    Al Roden Guest
    Default Smoke Detectors Inside HVAC Returns
    Is there an easy was to determine if this smoke detector is specifically listed for installation inside a return air chase?
    Default Re: Smoke Detectors Inside HVAC Returns
    Quote Originally Posted by Al Roden View Post
    That is not a smoke detector, it is a siren for an alarm system.
    Should not be in the ducts.
    I think this is the siren in the picture.
    http://intellahome.com/alarmpdfs/wave2.pdf
    Plastic smokes when burned.
    Even duct mounted smoke detectors are mounted outside the ducts and have a sampling tube going into the duct.
    Lansdale, PA
    It does appear to be a siren. I assume it is right next to a return-air grille. I see no harm in having it there, unless is interferes with the volume of the alarm, or the manufacturer does not permit it.
