Results 1 to 17 of 17
    Stephen Jenkins's Avatar
    Stephen Jenkins Guest
    Default Newbie - Doing Research, Got Questions, Need Constructive Help.
    @RTR Process Description pg7.pdf
    Hello everyone,
    I've browsed this site several times in the past and got a lot of good information. So since I can't find an answer to my specific problem, I decided to risk my neck and ask for help.
    I'm doing research for a remodeling job in Texas, I may take on. The owner/customer (who's acting as the General Contractor) on the project wants to "Raise The Roof". Since the roof on his 1960's home is still in good shape but at a 2:12 pitch, the plan is to raise each side at the center, and splice a 19" extension to each of the 2x6 rafters. My plan is to nail 1/2" plywood doublers (6" x 32") to both sides of the rafter and extension. I've worked out the problems of how to raise the roof, but I'm concerned that the city inspectors may have a problem with splicing the rafters. I've attached a page from the project description that shows the center section framing and rafter splicing that I came up with. The answer I haven't found is, will this fly with the inspectors?
    Yay's, Nay's, and suggestions needed.
    Thanks.
    Default Re: Newbie - Doing Research, Got Questions, Need Constructive Help.
    Quote Originally Posted by Stephen Jenkins View Post
    Hello everyone,
    Thanks.
    Nay
    HO acting as the GC?
    If the HO is the GC why are you asking?
    Can a HO be the GC in Texas?
    I doubt that splices in the rafters will be acceptable to the AHJ.
    Hire an architect and a real general contractor.
    The city will issue the HO a permit with him listed as GC, he is allowed to hire help, and I'm it.
    I'm trying to make sure that the remodeling will work, and allow the HO and his restricted budget to get the job done with reasonable assurance that it'll all meet code. He's going to put in more hours of work than I will. Hence, his idea, my plan.
    What sources are there on splicing rafters that would show how it should be done? There must be something that fits. This is a situation is as if the rafters had been damaged in that area and needed to be repaired, how could it be done correctly?
    Thanks for your input.
    Nay
    You can act as your own GC in North Carolina. People put too much faith in the GC license. The GC is mostly about the legal contract, hence the name "contractor", not so much about the actual construction and definitely not about structural design.
    I'm not a architect or engineer, but I agree with Jim, I don't think this design will fly. One of the problems not addressed is point load at the birds mouth cut that will now have a new angle. Around here anything that has this much of a design change needs a licensed engineers stamp on the plans.
    I just don't see it.
    Let us (me) know how it turns out.
    Around here a HO is not allowed to act as the GC anymore, even on his own property.
    I know what you mean
    However the GC does have insurance, some training and has passed a state given exam.
    A HO has none.
    I think you meant Rick
    Yep
    With the blessing of an architect or engineer, the AHJ may approve the HO as GC.
    First, I can't imagine how you can properly modify an existing roof the way you described, and to do so meeting whatever code your area has. Splicing a rafter (or two, three, whatever) is a repair; splicing them all is completely different. Changing the pitch of an existing roof without removing everything sounds like a plan for disaster. Re-framing the roof is faster and it will be done right.
    In FL you can act as HO/GC, but that doesn't exclude you from having drawn plans and having it all blessed one stage at a time.
    Dom.
    I really don't understand why you are asking this question on a home inspector's forum instead of asking the AHJ directly on what they will or will not approve.
    In the end, it really doesn't matter if 27 inspectors here think your idea is the greatest thing since sliced bread, if the AHJ will not approve it.
    Welcome to the wild, wild west. Texas does not have any license for GC, Builders, or carpenters.
    A HO can do anything they want but may need to get a contractor to sign off on electrical, plumbing or HVAC.
    But no it will not work to do as you have explained, the code is a prescriptive method for building. If you stay within the normal methods, the code addresses that and you can follow the code. THERE IS NO CODE for what you propose which means the AHJ will not bless it unless he is blind or blinded by some green (SURELY NOT in TEXAS!)
    This does not mean it is not possible or even desirable, it just means you need an engineer to design it and bless it with his credentials, then the AHJ will bless it.
    Lansdale, PA
    Hello everyone,
    Thanks.
    Generally using plywood for splices is weaker than wood and the pieces you suggest using are probably too short. The number of nails is also important. Find a local structural engineer with a small practice (like a one-man company) familiar with engineering for wood frame construction. He (or she) can work that out is less than an hour, and maybe review other concerns. Anything less than a 3:12 pitch should be built with a structural ridge beam. Even at 3:13 to 4:12 pitch and no structural ridge the nailing requirements for the ceiling joist/rafter connections require many nails. A few hundred dollars in engineering on a few thousand dollar or more job is not much and could save a lot of problems.
    I am a structural engineer and much of my work involves evaluating and designing repairs for things that contractors did without having a clue as to whether it was correct.
    Its great that you asked the question, but most people on this forum cannot really answer it. I can do the calculations, but you need an engineered licensed in your state.
    Aug 2012
    Rock Hill S.C.
    ....the plan is to raise each side at the center, and splice a 19" extension to each of the 2x6 rafters. My plan is to nail 1/2" plywood doublers (6" x 32") to both sides of the rafter and extension.
    Nay
    Yay
    This is the only way it would pass around here as well.
    I ask the question here because my past browsing of this site gave me more to work with than any place else. Despite the tone that some of the conversations I observed here took, I felt that of what I was able to find on the web, this was the best place to start, even if no one agreed. I was looking more for suggestions and solutions than approval from the inspectors here.
    Based on the suggestions here, I told the HO this morning that he should get an engineer to look at the plans. He called me about an hour ago to tell me that he applied to the AHJ for the permit based on what we currently have. Now I'll wait and see what happens.
    Thanks to all who've contributed to the discussion.
    As an experienced carpenter who has built many additions, dormers and raised roofs, my vote is NO. Raising the roof works pretty well for small dormers, i.e. providing decent headroom for a new bathroom or at the top of a staircase.
    Raising the roof however does NOT work well with larger roof areas. The weight, size and potential hazards are far too great. Its much better to just cut the existing roof off and start fresh. As far as telling you how to do it, ABSOLUTELY NOT.
    Years ago a friend took over a job from a client who hired a guy who was trying to raise a room sized roof section, the entire roof section almost slid off into the neighbors yard while the neighbor and her kids were playing in the yard.
    If you don't have the skills for this type of job, find other work.
    Default Re: Newbie - Did Research, Answered Questions, Got Constructive Help.
    Rick,
    RTR Project completed.
    Inspection late last week, only open items were roof vent extensions that owner hasn't completed and the A/C work that's just starting (not me). Inspector peered into every nook and cranny. He was impressed with rafter extensions and purlin support structures. Needless to say the project took longer than expected. The owners portion of the work progressed at less than half the speed planned, and "Murphy" did not take a vacation.
    Next/New project is to do soffit and ridge vent construction and installation.
    Rick,
    Good for you, and glad you let us know the outcome.
    Got any pics? It would be interesting to see what and how it was done.
    Loaded several to RTR photo album.
    http://www.inspectionnews.net/home_i...r-project.html
    You da man.
    Good job.
