    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Staining on exterior wall near A/C
    Richard Rushing's Avatar
    Richard Rushing Guest
    Default Re: Staining on exterior wall near A/C
    Well... if there is not a condensate drain drop above it (from soffit) then it is discharge from the fan.
    Is this a heat pump?
    RR
    Kevin VanderWarf's Avatar
    Kevin VanderWarf Guest
    Looks like the fan to me.
    I've never liked that design.
    I'm sure the folks at Trane know there stuff, but if you put 4 bricks on each corner of any other unit then placed a piece of plywood on top, it would give you about the same air distribution as the unit in the pic.
    But then any other would require an 24" to 48" top clearance.
