Results 1 to 13 of 13
    Dave Rose's Avatar
    Dave Rose Guest
    Default Can anyone identify these items?
    Found these today in a main panel and it's the first time I've seen them. House built in 2010. The box below the main panel did not appear to go anywhere...there was nothing on the exterior of the house at this location. The panel was in the garage. Ideas? If you know what they are, then the next questions are obvious...what are they used for? Why? Why have I not seen them before?
    Also, why can I not insert a carriage return in this forum? When I hit enter the text will not start on the next line.
    I can't get photos to upload...the uploader just spins and spins...file is only 122k, pretty small...ideas? Thanks, Dave
    Edit: I just changed from the WYSIWYG and now I can insert carriage returns...one issue resolved. I'll try posting the photos again now.
    Edit: I got photos to load by moving away from the enhanced interface...that seems to have been the issue.
    Default Re: Can anyone identify these items?
    Really going to need to see the pictures.
    Dave Rose's Avatar
    Dave Rose Guest
    I know, but I can't get pictures to upload as I said previously...now I need help with that.
    Quote Originally Posted by Dave Rose View Post
    https://www.google.com/search?q=elec...w=1024&bih=667
    They look like current transducers, possibly part of an energy monitoring system.
    You might want to check out something like the TED 5000 IIRC.
    They are sensors for a type of meter.
    Kinda like a clamp on amp meter.
    Congrats there Quick Draw.
    *both post 8:48
    *both post 8:48
    Does that make you this guy?
    Nope .
    Hanna-Barbera -- Snuffles - YouTube
    Jan 2014
    India
    I am totally agree with Rick Cantrell, they are sensors for a type of meter.
    Thanks..
    Epackpolymers.com
    Here you go... Cent-a-meter
    Monitor your electricity use to find REAL savings!
    Gerry Bennett's Avatar
    Gerry Bennett Guest
    Looks like a cheap version of the Emon-Demon, metering devices used a lot to monitor the energy use for an apartment or part of a building when you don't actually have a power co. meter. It counts kw hours and then you figure out the usage by whatever the POCO charges per kw hour.
    Mbrooke's Avatar
    Mbrooke Guest
    Current transformers. I think the other posters explained it better than me. Safe, yes, I know many in operation. However if its code compliant since its not part of the listed enclosure Im not really sure. Some else would probably know more than me.
