Results 1 to 14 of 14
    Nampa, Idaho
    Default Roof has a little moss growth on the north side
    Today's inspection. This is most significant moss growth I have found in a long time. I'm located in eastern Washington (the dry and sunny side of the state). This place was not shaded or located up in the mountains.
    Default Re: Roof has a little moss growth on the north side
    Trent,
    Are you sure it wasn't a sod roof that hasn't been watered in a while?
    Nampa, Idaho
    Trent,
    It's a 3-tab shingle on a gable roof.
    NoCal
    Great shot of the roof.
    how old was the roof...or the house?
    what about the south side of the roof? Got a comparison picture?
    Never seen asphalt shingles with moss growth that extensive. If you had not stated it was three tab I would have called this out as a wood shingle roof.
    Nampa, Idaho
    Here's a few more picks, one is on the south side. You get an idea that the roof is probably at least 30+ years old. Home is a 1915 built Craftsman in distressed condition.
    I visited Ireland a few years ago.
    ALL roofs are covered just like that.
    The tour guild said roofs last 40+ years.
    If that's true, where can I get some moss for my roof?
    Jun 2013
    Virginia
    Nice... One of those "green roof systems". Needs some water.
    James Kollhopp
    www.WeInspectItHomeInspections.com
    "Promise only what you can deliver. Then deliver more than you promise."
    Rick, as you know, those Irish roofs are probably slate, and they probably only need a few repairs after 40 years.
    Moss on the roof is a serious problem here. It holds moisture and debris and that just leads to trouble. Powerwashing by demossing contractors does even worse damage.
    Aug 2010
    BC Canada
    Well. time to replace the roof. Why bother the moss?
    don agel's Avatar
    don agel Guest
    Do you refer this one to a licensed roofing contractor or a licensed landscaper? lol
    David Caldwell's Avatar
    David Caldwell Guest
    Awesome pictures! I wonder what the ceilings looked like on the inside.
    Nov 2010
    New Westminster BC
    You can tell it's Eastern WA because the moss is brown. In Western WA or SouthWest BC it would be green. Quite a few similarly mossy roofs around here in older residential areas but almost always on garages and sheds, not houses.
    don agel's Avatar
    don agel Guest
    Quote Originally Posted by David Caldwell View Post
    Guess that would depend on the amount of rain and how fast the moss can absorb it.
