Results 1 to 2 of 2
    Clay White's Avatar
    Clay White Guest
    Default Re: understairway fire blocking
    On the concealed wall side, fireblocking should be installed at the angle of the stringer and aligned with the bottom of the stringer.
    On the non-concealed side, nothing needs to be done ... fire would just jump around everything and anything anyway as it is all exposed.
