    Default gas shut off inside furnace cabinet
    This seems obviously wrong, but I don't think I've ever seen it before so never asked.
    Default Re: gas shut off inside furnace cabinet
    Hi John. Good to see you're back at inspecting.
    I've seen this same setup a few times and also called it out as incorrect.
    Hi John. Good to see you're back at inspecting...
    Thanks, Nick. Here's my description of what atrial fibrillation feels like: Two squirrels having a wrestling match inside my chest.
    It's wrong.
    Of course, that's not the only problem in there...
    I'd write it up as a hazardous defect. The majority of the time I test those older brass valves they leak.
