Results 1 to 3 of 3
Thread: Drain sounds
    dan orourke's Avatar
    dan orourke Guest
    Default Drain sounds
    Michael Larson's Avatar
    Michael Larson Guest
    Default Re: Drain sounds
    Don't know for sure.
    It should not gurgle if the system is free flowing on the drain and vent side.
    It may indicate a slow or blocked drain downstream of th bath drain.
    Quote Originally Posted by dan orourke View Post
    I filled a bathroom sink to rim. When I let it drain, everything sounded fine. Very quiet. At the very end when the last of the water was draining out, a loud gurgling noise was heard.
    A defect or not a defect?
    Dan,
    If the drain water is swirling at the end of the end of the drain cycle thats a good thing.
    If it's bubbling at the end it's a bad thing. Sound or no sound.
