    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Chimney Flue / Insulation Shield
    Default Re: Chimney Flue / Insulation Shield
    If that is the fire-stop (not insulation shield) that is part of the manufacturer's listed components for that pipe, then all is well. If it is a different brand, then it is wrong, no matter what the fit is.
    However, I never get to see all the parts and installation instructions, but that looks similar to most I have seen.
    Healdsburg, CA
    It's wrong and Jeff I think you already figured that out?
    Jerry McCarthy
