Results 1 to 3 of 3
    Clay White's Avatar
    Clay White Guest
    Default What type of chimney crown?
    Jon Randolph's Avatar
    Jon Randolph Guest
    Default Re: What type of chimney crown?
    It looks like it may be the quick setting grout like cement.
    The crown is a water entry point. It does not extend past the edge of the chase and I can envision it wicking water into the chase.
    The counter flashing should extend farther to at least cover up the chimney flashing.
    Cool Re: What type of chimney crown?
    There are many elastomeric coatings available to sweeps for coating crowns. Could be one. However, doesn't do much good if those cracks and seams are not sealed. Capillary attraction will draw water in under this crown and it will fail.
    HTH,
    Bob
