    Sep 2007
    Fredericksburg, VA
    Default Another - Anyone Know What This Thing Is?
    This doohickey was on the supply line from a well. No other information was visible. I have never seen one before.
    Stu, Fredericksburg VA
    Default Re: Another - Anyone Know What This Thing Is?
    I had never seen one till I saw this one. But I know what it is. It is a valve on a well water line.
    You can set the valve by degrees to reduce flow. This way the pump, probably a submersible, can only deliver what you allow it to. Keeps the pump from sucking air where there is a slow recovery.
    Sep 2007
    Fredericksburg, VA
    Thanks! Now I know.
    It obviously allows one to adjust the angle of the water coming out of the pipe!
    877-466-8504
    Dec 2009
    Denver, CO
    If there is significant sediment in the well, it can be avoided by limiting the flowrate from the well. I have used this technique on a personal well, which will pump 12 gpm with lots of sediment, or pretty clean water at 2 gpm.
    St. Louis, Mo. area.
    Quote Originally Posted by Dana Bostick View Post
    I think I like your answer. It's obviously being used to avoid having to install so many elbows in the piping.
