Thread: Charger Needed Tiff 8800?
10-18-2007, 11:52 AM #1
Ladies and Gents,
I looking for a plug in charger for my Tiff 8800 Gas Sniffer. Or a way to charge the C cell
size batteries but they are 2.4 Volt each instead of standard C 1.5 Volt.
Similar Threads:It Might have Choked Artie But it ain't gone'a choke Stymie! Our Gang " The Pooch " (1932)
10-18-2007, 12:01 PM #2
Re: Charger Needed Tiff 8800?
Contact the Manufacturer to purchase a replacement charger.
EBay may also be an option...
10-18-2007, 12:06 PM #3
10-18-2007, 12:09 PM #4
TIF 8800 PORTABLE COMBUSTIBLE GAS DETECTOR, TIF INSTRUMENTS, INC. - Mfg# 8800
Gas Detector Battery Charger$29.95Add
TIF 8800 Series Gas Detector Battery Charger
Item #: G277
Manufacturer: TIF Instruments
Manufacturer Item #: 8803A
Product Type: Gas Detector Accessories
Your Price: $29.95
In Stock
rr
10-18-2007, 12:17 PM #5
10-18-2007, 01:03 PM #6
Maybe this will help:
There are actually 4 total NiCad cells in those, each battery is 2 cells, so you wouldn't get the same voltage from 2 C batteries.
Last time I had to replace the batteries in mine, I got a local battery shop to build me a couple of NiMh batteries for it. Takes a couple more hours to fully charge them, but they last more than twice as long on a charge, can be recharged at least twice as many times before you have to replace them, and don't self discharge nearly as fast when you are not using it.
from : TIF 8800 combustable gas detector - HVAC-Talk: Heating, Air & Refrigeration Discussion
------My comments:ML
If you are handy you might be able to stack 4 AA together and get get clse to the size of the original pack.
Ni-CD are appx. 1.4 -1.45 volts per cell when fully charged. 4 x 1.4(nom) = 5.6- 5.8 V
4 x 1.5(AA)-6 V would bet you close to the correct terminal voltage.
10-18-2007, 01:30 PM #7
Thanks Michael,
After reading your link might be time for a new sniffer.
What are you using?
10-18-2007, 02:13 PM #8
Billy, as god is my judge I just tossed one into the garbage this afternoon. If I can retrieve it you can have it for the cost of postage.
10-18-2007, 02:27 PM #9
10-18-2007, 02:39 PM #10
