Results 1 to 2 of 2
    Oct 2012
    Massacusetts
    Default Looking for a solution to freezing pipes
    My synagogue has an annual issue with pipes freezing some are below slab others are on an outside wall. (this is a common problem with churches as well)
    Yes I know - it never should have been done that way.
    Since the building is empty for a couple of days a week chances for a freeze up increase and I have thawed them twice in the last week
    I have thought about connecting a small circulating pump from the hot water feed to cold water with an isolation valve (connecting this permanent, possibly with temperature controls) but I do not know if this is legal also need to find a small pump something around 1/10 gal per minute.
    I am also open to some other ideas
    Default Re: Looking for a solution to freezing pipes
Tags for this Thread
