Results 1 to 4 of 4
Thread: Mobile Home SEC
    Default Mobile Home SEC
    Sparky said the SEC on the ground was code compliant. I don't care that much, as it is a no brainer to me that the cord should be protected from physical damage. I just wanted to clarify if that is indeed compliant for a mobile home or if it would be required to be protected. Does anyone know the current code for mobile home SEC? I know they have their own codes on a lot of things.
    The seller is pissed because it didn't sell, so he fired off a letter to me stating all of the "mistakes" on my report.
    Default Re: Mobile Home SEC
    In most areas manufactured homes fall under the Department of Transportation. HUD has a good amount of information on them, and I bet that you could support your findings with the NEC.
    Me, I would not even bother replying to the seller.
    Myrtle Beach, South Carolina
    To the best of my knowledge, it is acceptable for 50 amps or less. Greater than 50 amps needs to be in a conduit. However, as a consultant, you certainly have the right and responsibility to recommend more than the bare minimum requirement. A rubber cord lying on the ground is subject to physical damage and protecting the cord is a really good idea.
