Results 1 to 4 of 4
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Staining on Factory FP damper
    Default Re: Staining on Factory FP damper
    Looks like rust to me, water is the cause. The question is what is the source. Did you get a look at the cap?
    Fireplace smoke dampers not equipped with a water-letlerr-outer usually look like that.
    If they kept the home fires burning, the heat would keep that from happening.
