Results 1 to 15 of 15
03-14-2014, 02:49 PM #1
Identification of safety glass in doors and windows
I inspected a house today built in 1996 and one interior set of French Doors had glass panels. I suspect this is safety glass, however there was no visible etching on the glass panes to determine if they were in fact safety glass. Question, in the mid-1990's were there some safety glass that was not identified? When did the identification etching of safety glass begin?
03-14-2014, 03:09 PM #2
Re: Identification of safety glass in doors and windows
Hi Jim, the reason I was asking is I believe on a multi-pane door (door with several glass panels) that on that type of door, if the glass panels are less than one square foot each, no etching is required. I may be wrong about that however, but I believe it is in the IRC. But like I said, I could be wrong.
03-14-2014, 03:11 PM #3
From - Safety Glazing | The ASHI Reporter | Inspection News & Views from the American Society of Home Inspectors
And I think this speaks to your actual question -In 1972, the U.S. Congress enacted the Consumer Product Safety Act, which created a new government agency, the Consumer Product Safety Commission (CPSC). When it opened its (glass) doors in 1973, one of its first tasks was to address the hazards of glass. Though armed with the ANSI standard, the commission went beyond it, and developed a two-tiered standard. A person will typically bear more of his or her body weight in impact with a large piece of glass than he or she would with a smaller piece. The CPSC standards resulted in Class I glass rated at 150 foot pounds of impact, and Class II rated at 400 pounds. These became part of CPSC 16 CFR 1201, and they became law on July 6, 1977. These designations may sound familiar, as they are seen on the identifying “bug” used in tempered glazing today (see Figure 1).The ANSI standard has since changed and now includes three impact categories. Classes A & B are similar to CPSC’s Category I & II, and Class C has the 100-pound rating. This voluntary standard did not require the classification to be marked on the glass until the 2004 edition.
03-14-2014, 03:13 PM #4
Still is that way if ...
- From the 2012 IRC
- - R308.1.1 Identification of multiple assemblies. - - - Multipane assemblies having individual panes not exceeding 1 square foot (0.09 m2) in exposed area shall have at least one pane in the assembly identified in accordance with Section R308.1. All other panes in the assembly shall be labeled "CPSC 16 CFR 1201” or "ANSI Z97.1” as appropriate.
... did you check all the panes?
Probably since the beginning of it being required, as I recall, it was first required in Los Angeles around 1965, give or take a couple of years.When did the identification etching of safety glass begin?
03-14-2014, 03:18 PM #5
The bottom line remains though, if there is no "bug" on the glass the only way to know is with the "hammer test" .
03-14-2014, 03:19 PM #6
03-14-2014, 03:29 PM #7
03-14-2014, 03:35 PM #8
I got caught by surprise too when I first found that section and allowance for one pane to be identified.
I was in my third day of inspecting a house which had 40 pairs or 15 panel French doors and happened to find that section at night while working on the items already found, the next day I had to check all 80 doors
and, sure enough, one bottom pane in each door was identified.
But, as Jim said - the only way to know for sure is the hammer test.
Was it as was it not, only the hammer knows (to the tune of 'does she or doesn't she, only the hairdresser knows')
03-14-2014, 03:38 PM #9
03-14-2014, 04:25 PM #10
03-14-2014, 04:55 PM #11
03-17-2014, 10:15 AM #12
03-18-2014, 04:42 PM #13
03-18-2014, 04:53 PM #14
03-18-2014, 07:28 PM #15
