    Ron Bishop's Avatar
    Ron Bishop Guest
    Default interesting drain...
    What do you think about this fancy drain system?? I have never seen a coupling like this before...
    Default Re: interesting drain...
    You lucky dog. You must have had a great day under there. Is that rubber, or plastic. I've never seen one. Obviously it dosen't work very well.
    Colorado Springs, CO
    Is that a neoprene boot from a roof jack?
    Bruce Breedlove
    www.avaloninspection.com
    South-West Michigan
    Thumbs down Re: interesting drain...
    It's leaking.
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    Brandon Chew's Avatar
    Brandon Chew Guest
    Speaking of creative uses for plumbing boots....
    If you have the November 2007 issue of Family Handyman magazine, check out the article on page 18. They are showing Joe Homeowner how to use a rubber plumbing boot to flash around pipes & wires where they penetrate the exterior siding. The method involves taking the boot, trimming it, face gluing it to the siding with silicone caulk, and then pumping it full of foam-in-a-can.
    Brandon,
    "Family Handyman Magazine"? You're joking, I hope.
    Brandon Chew Guest
    Gunnar - I kid you not!
    Attached Files Attached Files
    Philip Perez's Avatar
    Philip Perez Guest
    Talking Re: interesting drain...
    I should have written that article for "Handy whatever magizine", and charged a few bucks for it.
    Although I hate to admit it, I've actually done that on a rental property with a serious mouse problem.
    Joshua Hardesty's Avatar
    Joshua Hardesty Guest
    Places like Lowes and Home Depot sell those. They're all rubber, like the "fernco" brand connectors with two clamps at either end. However instead of just couplings, they make them in everything -- 90's, 45's, tees, wyes, etc.
    That looks like someone used one of those bands over a piece of pipe that was smaller than the hub of the rubber fitting, hence the obviously deformed shape and leaking. (Would you approve a 4" Fernco band to connect a 4" pipe to a 2" pipe?)
    Jan 2011
    Utah
    Annotate and refer for plumber inspection. I wonder if it is listed for use with iron pipe. (not)
