Page 1 of 2 12 LastLast
Results 1 to 65 of 93
    Oct 2012
    Shelby NC
    Default Anyone know about the reliabiltiy of these mini-breakers that replaced fuses?
    Default Re: Anyone know about the reliabiltiy of these mini-breakers that replaced fuses?
    I would be more concerned about the paint overspray. Ducking and runs for cover.
    Sorry Ren, couldn't resist.
    Oct 2012
    Shelby NC
    Good one, I was waiting for someone to bring it up. That took no time. This forum is relentless. LOL
    I wouldn't worry about the paint overspray, arcing will be confined to the aluminum wrapped thread portion of those circuit breakers, which means that reliability (not blowing) should not be a problem.
    Just like the Edison fuse that they replaced they work. Anecdotal report that after decades of use and no failure or problem.
    One note is that the original fuse may have been a 15amp. Have to look at wiring/outlets.
    The Insurance industry will have a hiss fit looking at them, just like having Edison fuses.
    Oct 2012
    Shelby NC
    Quote Originally Posted by Jim Abram View Post
    Ren - I think that you are missing the forest because the trees are in the way.
    The panel box is probably beyond its serviceable life and Insurance Companies are often refusing to insure properties with fuse boxes.
    No, I got that and have recommended replacement. But I have never seen these mini breakers and wanted to add to my comment if there was something to add.
    Quote Originally Posted by ren ramsey View Post
    These breakers work as intended, nothing to comment on ( concerning the breaker type.)
    As cheeze as it may look they work well. Function just as any breaker with the exception that it is visually hard to tell if it has been tripped. Push the center and it resets.
    I would take issue with the statement that it is beyond its serviceable life. The box and fuses work. How the insurance industry looks at them may be the reason that Jim offers that it is "probably beyond its serviceable life". Yet the equipment works fine. Like most things it is what people do to it that makes it hazardous.
    If you recommend replacement of anything make sure you really understand and explain the reasoning you are making that determination.
    If old is the requirement for serviceable life then many of us are in trouble. Though our wives may want to upgrade to a newer model, even though we are still providing good service despite not being as shiny as we once were.
    I bet those resettable fuses are 5 amps over fused for the circuit based on the age of panel. Most likely used because there is nuisance tripping. Up the fuse, and save buying one use fuses and never having replacements on hand.
    Mbrooke's Avatar
    Mbrooke Guest
    If Im not mistaken those have thermal trip only, no magnetic trip. A fault will leave behind a lot more carnage. Wont hurt the wires if its within spec, but one less safety feature over a breaker.
    Check those are the right size too.
    The main issue with fuse boxes is that there is a significant amount of written information that fuse boxes are dangerous and a potential fire hazard. ...... A fuse box should be reported as beyond its serviceable due to liability issues because they are a well known hazard.
    What is said/written repeatedly is that it is the person that made the box unsafe and caused the fire by installing a higher rated fuse. It is not the fuses, it is the people manipulating them. With a screwdriver you can do the same thing to a breaker panel.
    As for data to support that the Edison fuse panel is unsafe take a look, you will not find much. The data goes back to installing a higher rated fuse. Data is from the 80's and 90's at that.
    Jim,
    Do you have any statistics rather than opinion that the "fuse boxes are dangerous and a potential fire hazard. ...... A fuse box should be reported as beyond its serviceable due to liability issues because they are a well known hazard." What I see is that it is opinions that are stated without any supporting evidence. And again it is about people changing the fuse that caused the problem not the box with correct fuse ratings installed.
    Jim,
    Gary,
    You are correct in that a Human Being caused the hazard.
    That said the liability would be that as a Human is involved think young inexperience driver with a very fast sports car verses a beater. The probability of a loss is increased.
    Gary,
    Sorrry don't quite see the analogy. But no mater. It is the human factor. Fast sports car or 8,000LB beater the liability is what they hit and the damage they do all around. Still goes back to human factor.
    Car analogy, I can take a car that is designed and built to operate reliable and safely and make it into a death trap. Change the suspension and steering, boar out the engine and add some/alot of Nitros, beef up the rear end (sorry old school, now front wheel drive) and put on some fat tires and head to the supermarket at 140mph.
    It is not the car's original design that is hazardous, other than the ease to alter. It is the fact that the design is altered.
    I have been repairing microwaves for years. They have security screws that make it just a tad more difficult to dissemble. Just need a security bit set ($6) and you are off to the races. Similarly the thinking is that people will not pick up a screw driver and open a service panel and change the breakers. Naaaaaaaa that would never happen. So would that make the breaker panel hazardous and beyond its serviceable life?
    The difference in the design of the fuse as opposed to the breaker is not the issue. Yes the breaker has a different trip design yet they can melt down. Breakers are not totally fail safe are they? We have never seen a hot breaker in a box that no one knew about, have we?
    Intermission:::::::::::: Let all go to the lobby.....
    As a redirection to the fuse discussion you might look at the introduction of the Smart Meter that is being introduced. Locally here in Maryland the electric supplier is now in the process of installing Smart Meters with some push back. Take a look at : Smart Meter Fires
    Smart Meter Fires and Explosions | EMF Safety Network
    Yes opinions are a dime a dozen.
    http://www.esasafe.com/assets/files/...ety_Report.pdf
    Keep in mind these are stats from Ontario. While broken down by category does not go into what the specific cause was, nor age of panel, or any other pertinent data to categorically state old panels cause more fires.
    Googled "Fuse Box Hazard" and the first two pages are nothing but contractors and discussion forum topics.
    Can you provide a link to a government agency quoting stats as to your 'opinion?' The link I posted clearly shows empirical stats indicating your 'opinion(s)' are not necessarily based on empirical evidence.
    And if you are sure of your opinions at the very least quote a source rather than simply telling someone to google a term that doesn't show much of anything.
    Gary -If you Google -" Fuse Box Hazards " you will come up with thousands of articles about hazards with fuse boxes.
    It is these articles and opinions that create the issue. This is similar to the Federal Pacific issue.
    I liked this one. Go to the end for panel demonstration.
    Fuse Box Danger - YouTube
    https://www.youtube.com/watch?v=dY3o4HssHYA
    Jim, What you get is a lot of the same. People saying that people cause the problem not the box or the fuse.
    Raymond has seized on my point. Where is it that the Edison fuse and box are the hazard. Is there a source that demonstrates, by testing, the box and correct fuse are any hazard in and of itself. Is there a source that has determined failure that was not directly connected to someone making the box and fuse unsafe?
    Again the same point could be made about breaker panels. Breakers can be changed, a 30amp breaker can replace a 15amp breaker.
    Yep,
    It's the Human Nature Factor.
    Fast car inexperienced driver = Known Risk and Liability
    Slow car same drive = Less Risk
    Edison Fuse Box = Known Risk and Liabilty
    Breakers in enclosed Service Panel = Less Risk of an inexperienced Human altering the equipment to create a hazard.
    * if a fire is caused by something say as an altered Microwave the Insurance carrier could shift liability.
    So as not to be lost in the discussion 2 separate things.
    1) "Beyond its serviceable life", Box and fuses work and replacement parts are available. So not beyond serviceable life. Most of the comments in the Google search will say that the fuses work as designed to protect the circuits. It what is done with them.
    2) Insurance companies not willing to write coverage on box and fuses is something different. Yep, it is common that they will not provide coverage based on fuses being present.
    The risk is with the people because they are the hazard to the equipment. The equipment in and of itself is not the hazard.
    " Less Risk of an inexperienced Human altering the equipment to create a hazard." Lack of the ability to use a screw driver is the only experience that it is dependent on.
    Altered microwave may be hazard, but the hazard came from the person not the microwave.
    So again the hazard is with the person not the equipment. Just like the fuses in the box.
    Garry wrote in part:
    My experience is that some insurers will insure while others may not, while others may simply want a licenced electrician to inspect and state the service is okay.
    One size does not fit all nor should it be said the insurers will automatically not insure a premise based on fused panel.
    I have found insurers are more interested in Alu wiring and want generally speaking any 60 amp service upgraded to a minimum of 100 amp even though no authority had condemned 60 amp service, nor aluminum. It is the insurers who act as code authority even though they are not. They will reduce their risks any way they think suitable even though codes and authorities dictate otherwise.
    If this Equipment is in use it is a Hazard. ( Cars in the junk yard do not get in accidents.)
    The want or need to alter the service equipment is the driving force. ( Lights go out put a penny in the slot, or flip the breaker back on.) Which of these is less likely to create a hazard?
    So again you can not separate in use items from the Human ( other wise the item is not in use there for useless. ( what good is Electrical Service to a residence if no one uses it?)
    Not quite correct.
    The hazard is the ease with which the equipment can be altered from a relatively safe condition to an unsafe condition.
    When a fuse blows, the fuse must be removed and replaced with a different fuse. The new fuse being installed will likely be "what is within reach" regardless of rating. Replace the fuse a couple of times and a higher rated fuse will likely be installed so as to eliminate the problem.
    A fuse panel is also older and will likely have less capacity and fewer circuits - thereby creating the fuse blowing problem.
    If a breaker trips, the breaker is not removed, it is simply reset.
    breaker panels are typically newer and have more capacity for more circuits - thus breakers trip less often than fuses blow.
    When breakers trip, usually there is a circuit problem more than an overload problem as with fuse panels.
    Thus, fuse panels are more of a hazard than breaker panels and why insurance companies do not like fuse panels.
    No personal opinion? Okay whatever you say! 10-4 over and out.
    Your reading comprehension is lacking . Read the post again .I do not have a personnel opinion on this subject.
    Not just one???????????????????????
    Maybe it is like Bill Clinton and the meaning of "is". An "opinion" by any other name still smells as sweet.
    Full Definition of OPINION
    1
    a : a view, judgment, or appraisal formed in the mind about a particular matter
    b : approval, esteem
    2
    a : belief stronger than impression and less strong than positive knowledge
    b : a generally held view
    3
    a : a formal expression of judgment or advice by an expert
    b : the formal expression (as by a judge, court, or referee) of the legal reasons and principles upon which a legal decision is based
    So, Jim you don't have an opinion. Maybe you have religion, where first you must believe and then you will understand. You have the understanding and need no source of support other than others opinion.
    Please don't go to a Flat Lander Society meeting, you might then just go over the edge...
    Not quite correct.
    The hazard is the ease with which the equipment can be altered ....
    The argument is that the ease of making something hazardous makes it past its serviceable life and by that ease makes it hazardous?
    If you remove the insurance industry position as the defining information source. Where do you find the supportable statical data that fuses are inherently hazardous and also that they are past their serviceable life and should be replaced.
    Jerry, I know you have a lot of information and resources at your disposal. Can you provide the data (or source location) showing fires relating to residential boxes using fuses. Numbers of boxes in use, the number that are altered, fires or damage attributable directly to the fuses.
    I seem to find more information on Smart Meters and related and related damage than statical information on the Edison screw in Fuse.
    A little interesting that millions have been spent on every type of study under the sun and I can't find fuse related studies.....
    Jul 2010
    Eatonville, WA
    I have experience with this type of breaker.
    My previous home had the basement served by a 4 position fuse box.
    Although I have no control over it now, but I am quite sure that it still has the indelible felt marker stating "15 AMP ONLY".
    These breakers served me well. A shop vac and additional loads occasionally would pop the breaker.
    I would rather push the reset button, than change a fuse.
    I think this is when the 'accidents' happen. If a 15 amp fuse isn't available and you find a 20 ... and you know, just until you pickup a 15......
    I have never done this, but I can see how this happens.
    I always stored additional 15 amp fuses near the box and got rid of any other sizes from the area. The push button breaker helps minimize the change of an errant swap.
    Still waiting to see if anyone posts some real data on their inherent dangers.
    Glenn Cummings
    Eatonville, WA.
    Quote Originally Posted by Glenn R Cummings View Post
    Really,
    This type of service equipment has not been installed in residential housing scene the late 1950's.
    Under this line of thinking Natural Gas lighting, knob&tube wiring, coal fired boilers, lead pipes, uninsulated walls & ceilings, wood cook stoves are all not beyond service life with No Hazards.
    The photo by the original poster only shows that the box may be over fused. Nothing else. Does it have to be replaced? That depends on what is behind the panel door, as such I would not be making any recommendation until such time as I could view what is behind the cover, other than its possibly over fused.
    Really,
    Natural Gas lighting not very practical anymore, and yes hazardous by design.
    Knob & Tube, Yes hazardous by design.
    Uninsulated walls & ceilings, definitely hazardous and beyond service life they need to be removed
    Wood cook stoves, most people should not play with matches.
    Coal fired boiler, definitely the average person today are not smart enough to operate.
    Lead pipe, if you are not drinking bottled water you deserve lead pipes.
    Under this line of thinking since black pipe for natural gas has been replaced by CSST, black pipe is not beyond service life with NO Hazards.
    Because it has not been installed since the 50's does not mean that it does not work and in and of itself hazardous. It was not to long ago that a poster suggested that breakers 20 years old should be replaced due only to age. Which was proven wrong.
    Should a report state that: As the new owner of a property you are to stupid not to understand that installing an incorrect fuse is bad. Therefore I have determined that the load center needs to be replaced with something that you will need a screw driver to alter.
    Here is a thought; Cars come with a temporary limited use tire. That tire should be replaced with a full size tire same as the rest of the car since the owner might not use it properly according to design and manufacture use specifications. Injury and death may occur and therefor is hazardous and never had a useful life.
    So you think bottled water comes from, Alpine Glaciers, Mountain Springs, Artisan Wells
    *or the muni water supply at wherever the bottler is located.
    You sure you want to go with the Donut spare as a comparison?
    Spare Tire
    Your Mazda has a temporary spare tire.
    The temporary spare tire is lighter and smaller than a conventional tire, and is designed only for emergency use and should be used only for VERY short periods. Temporary spare tires should NEVER be used for long drives or extended periods.
    WARNING
    Do not install the temporary spare tire in place of the front wheels (driving wheels):
    Driving with the temporary spare tire on one of the front driving wheels is dangerous. Especially on ice or snow.
    Handling will be affected. You could lose control of the vehicle and have an accident. Move a regular tire to the front wheel and install the temporary spare tire to the rear.
    CAUTION
    When using the temporary spare tire, driving stability may decrease compared to when using only the conventional tire. Drive carefully.
    To avoid damage to the temporary spare tire or to the vehicle, observe the following precautions:
    Do not exceed 80 km/h (50 mph).
    Avoid driving over obstacles.
    Also, do not drive through an automatic car wash. This tire's diameter is smaller than a conventional tire, so the ground clearance is reduced about 25 mm (1 in).
    Do not use a tire chain on this tire because it will not fit properly.
    Do not use your temporary spare tire on any other vehicle; it has been designed only for your Mazda.
    Use only one temporary spare tire on your vehicle at the same time.
  30. #30
    Billy,
    Naaaaaa--- I thought that bottled water came from France. Only the best for me Acqua di Cristallo Tributo a Modigliani.
    And if the instructions for using the spare tire aren't followed it has to be the tire's fault not the person using it. Because the instructions are so easy not to follow.
  31. #31
    Billy,
    People are Hazardous ! Just more so when they have access to products that require thought and common sense to use. That's why some laws are on the books to limit that access.
    *you'll need some of this Gold Booty Wipe to go whit ya High Class WaWA cause it be getting Deep round here.
    "Weird Al" Yankovic - Fat - YouTube
  32. #32
    Marshall Brown's Avatar
    Marshall Brown Guest
    It seems like we have a lot of beliefs about what and when it is appropriate to report something as no longer serviceable, or potentially dangerous.
    My thought is that if a device has not been ruled no longer suitable for use, is not worn to non serviceable condition, has suffered no damage that would impair safe function for the designed purpose, is only in use for the designed purpose and has not been improperly modified then it is still to be considered suitable for continued use. Old doesn't count.
    That is not to say I might not recommend replacement for a number of other reasons, such as ability to find qualified service people, ability to have ready access to proper repair and maintenance parts, there are safer ways of performing the function, there are more efficient ways of performing that function, or even simply ease of use. These are included in the report as Maintenance Tips or Improvements.
    My point is that if we write up something as being in need or repairs or replacement that should not be based on debatable issues or opinions but on clearly, and inarguable, demonstrable facts. If we do and the deal goes south because of it our client may not sue up but the homeowner might. DAMHIKT.
  33. #33
    When I tell a client that a five year old roof covering should give reasonable service for another 20 -25 years I also tell them that that is statistically true but may not be their experience.
    Much the same story applies to a water heater. I have seen water heaters essentially fail out of the box and others that seem to be impervious to the passage of time.
    It's a bell curve type thing. A water heater, and many, if not most other things, are designed to have about 95% of the product exceed the warranty period. A water heater, and many, if not most other things, WILL fail eventually. The trick is not so much to predict the time of failure but to prepare for it.
    As an aside, in the "good old days" they didn't really know how to design to an expected lifespan so they often just built things to last forever. I guess we'd all be out of work if that were still true.
    Historically we have provided our clients with a brochure, similar to the InterNACHI table, that gives many expected life spans for home products. I really do need to have some more printed up to include with our reports. Thanks for the reminder.
  34. #34
    The "aside" wasn't really meant to indicate that things actually last forever but more to point out that now we actually design for a life cycle. I don't think in the "good old days" they would have thought much of people who build things to wear out in a given time frame. But that's mainly a philosophical thing.
    Actually I don't have a problem with telling a client something should be replaced if that's the case. I just like to be clear, and correct, about why it should be replaced, and I realize I'm not always.
  35. #35
    ..... That's why some laws are on the books to limit that access.
    So are there any laws that require the replacement of the Fuse box when there is nothing else effecting the installation?
  36. #36
    Red face Re: Anyone know about the reliabiltiy of these mini-breakers that replaced fuses?
    Wow Gary,
    *took ya this long for a come back?
    My quote is out of content.
    Examples of laws on the books that limit access to hazardous items that require thought and common sense.
    *driving while intoxicated. * possession of hazardous chemicals without proper instruction or license to include drugs, explosives. * practicing a Profession needing vetting to protect others such as Doctor, Architect, Engineer, Pharmacist.
    So ya see Gary some of us use more thought and common sense than others.
    *that said I wouldn't want my Podiatrist writing a Remedy for my foundation crack.
    MC Hammer - U Can't Touch This - YouTube
    Last edited by Billy Stephens; 04-07-2014 at 06:34 PM. Reason: spelling. than replaced that
  37. #37
    Out of curiosity, I called three friends that write insurance in the Knoxville area. They all said they had no problems writing policies on homes with fuses. However, they all have problems with knob and tube
    - - - Updated - - -
  38. #38
    Farmers mutual underwriting guidelines are below . The loss ratio of both K&T and fuses is off the charts and most Companies deny coverage for either of these and often Aluminum branch circuit.
    Jim,
    Could you contact your Farmers or other sources and obtain the " charts" that are refereed to?
  39. #39
    Yes I would love to see the stats too, that is only one insurer out of many.
    Fuses are actually safer than breakers...
    - - - Updated - - -
    Billy S. wrote in part..
    Laws do not instill common sense, nor do they limit access, they only prescribe outcomes for lack of common sense and penalties for breach of same.
  40. #40
    Wow Gary,
    *took ya this long for a come back? ......
    *that said I wouldn't want my Podiatrist writing a Remedy for my foundation crack.....
    Off to the shore and off the grid..
    Where does common sense come from, wish I knew. Many intelligent people have none and some of the least intelligent will be overloaded. Where does governmental control to create common sense, for those that have none, exceed common sense. Extrapolation is that you should be licensed to buy chlorine and ammonia, since you could mix them and kill your self or others.
  41. #41
    Raymond,
    You can not freely buy certain goods or provide certain services. That is limiting your access.
  42. #42
    Ren - ...
    The Insurance Companies have issues with fuses because of the loss data . Houses with fused panel boxes have many more fires that houses with circuit breaker panel boxes.....
    The main issue with fuse boxes is that there is a significant amount of written information that fuse boxes are dangerous and a potential fire hazard...... A fuse box should be reported as beyond its serviceable due to liability issues because they are a well known hazard.
    So; no data, charts or statical information. "Sorry Gary - This data is not generally available to the public." The criteria for the fuse box being beyond serviceable life and are a well known hazard is a bunch of people, saying the same thing, with nothing offered to support that opinion. Something like listening to the boys at the bar. Opinions with nothing to support them but the stool they are sitting on. After a while they will start quoting each other as fact.
    Fuse box is not rusted and no damage of any kind. The fuses are the rating for the wiring. Therefore the fuse box is beyond its serviceable life and is a hazard. The federal Pacific case is different in that the hazard is in the equipment itself and not the operator.
    Its about what is being said. To often HI reports are filled with self aggrandizement and opinions without factual basis. Such as "Because your breakers are old they need to be replaced". Telling a client that there will be an issue (depending on state) of obtaining insurance for a property that has a fuse box is fine. Also informing them that they may need to replace the fuse box with a breaker panel to obtain insurance with a lower cost, is also fine. Saying that it is an insurance industry issue is fine. Explaining why the insurance industry has decided to make an issue of the fuse box is great. Telling your client that they have no common sense and can not be trusted to act responsibility is a individual decision on the HIs part. Saying that the working fuse with no defects, like a breaker with no defects, is not functioning as designed (serviceable ) is something else entirely. Granted it's splitting hairs.
    Maybe I should be in Missouri so I can say "You have to how me"
    "...story gives credit to Missouri's U.S. Congressman Willard Duncan Vandiver for coining the phrase in 1899. During a speech in Philadelphia, he said:
    "I come from a state that raises corn and cotton and cockleburs and Democrats, and frothy eloquence neither convinces nor satisfies me. I am from Missouri. You have got to show me."
  43. #43
    How would you know that the wiring is rated for 20 amps???
    * my swag would be 15 amp feeder lines.
    Foolish man shoots himself in the leg. - YouTube
  44. #44
    Garry,
    Don't feed the alligators, the bears, or the Troll ... they are not our friends - they would just as soon bite off the hand which is feeding them as they would take the food from that hand.
    If a response to the Troll is necessary, the best response is to stay on topic and reply to the readers.
    I wish I could claim that good advice above as mine, but that good advice above was recently passed my way from a friend on the board here.
    I think we are discussing two different issues.
    On the one hand there is the physical condition of a component of the house.
    On the other is some organization finding that it is not acceptable for some reason.
    My personal feeling is that we report the component as physically serviceable but no longer desirable/acceptable by reason of improvements in the technology and/or de facto rules/regulations.
    Wandering back to the water heater example several of us used above, is a seller obligated to replace a water heater that is out of warranty or might be past its statistical life span if it is fully function with no damage? I would guess no.
    Should we advise our clients that the water heater is older, less efficient, and that its failure might lead to other damage. I would guess yes.
    I still see these as two different issues.
  46. #46
    Not sure what what you are trying to say..... But 14/4 = 15 amp,,,12/2 =20, amp is what I would be looking at....
  47. #47
    How can you tell what gauge wire those 20 amp fuses are sitting on?
  48. #48
    Gary - You don't seem to get it . The Insurance Companies are ceasing to insure homes with fuses. No Insurance , no mortgage, and no sale. It is just that simple and you are not going to change it.
    I would suspect that most states have insurance companies that will insure what the other companies will not. In Maryland it is called The Joint Insurance Company. Long story short, they do not realty compete with the main stream companies. I would think that other states have something similar.
    - - - Updated - - -
    Look at them?????? They all taste the same. Just like chicken..
  49. #49
    Don't feed the alligators,.
    There is always a hope that something beneficial may surface.. Always worth a try.
  50. #50
    Quote Originally Posted by Marshall Brown View Post
    .... is a seller obligated to replace a water heater ...
    The seller is not obligated to do anything except pass the title. In reality the seller doesn't even have to pass a clean title, just a quitclaim deed.
  51. #51
    Look at them??????
    How can you support your statement that the panel has the proper size fuses from the OPs posted photo. You looking ?
  52. #52
    Post #5
    .......One note is that the original fuse may have been a 15amp. Have to look at wiring/outlets.
    Sorry Billy, the wording of your question threw me since I didn't say that the panel had proper anything. I origionally questioned the sizing of the fuses. Just like I would if they were 20amp breakers controlling the lights. Combination makes me suspect.
    If you look just from the outside at a breaker panel how do you know if the breakers the correct size for the circut they are connected to?
  53. #53
    Looking at the branch circuit wiring going into the box would be a start as to whether the fuses are appropriately sized, then again that is not always conclusive without taking the cover off.
    Regardless, fuses are safer, the panel does not ware out as being argued as most panels are never exercised to wear out. Screw in fuses do not wear out, cartridge fuses don't wear out.
    Still waiting for empirical data on fire losses as a result of failure of old panels. I provided such proof and its time for you Mr. Abram to do the same rather than meaningless opinions based on your narrow view of inspecting regardless what 'some' insurers are doing is not indicative that all insurers are turning down coverage for such panels.
  54. #54
    Jim, Thanks for the link. I haven't plowed through all 189 pages but think it will make an interesting read.
    "Products that, even though they may not deteriorate with age, no longer provide as much fire protection as alternative products now widely used. Age is indirectly related because it correlates with the degree of usage of these alternative products. Circuit breakers and fuses are always cited as an example, but the FPRF study, like the NIST and CPSC studies, did not find a clear difference in performance between fuses and circuit breakers. All those studies tend to indicate that old fuses and old circuit breakers work well if not abused or misused. Fuses are easier to defeat through tampering, and this appears to be the key to any statistical difference in performance. "
    Things don't have to be old or damaged to warrant replacement.
  55. #55
    Sep 2010
    NY Finger Lakes Area
    Raymond - You asked for the data .Find it posted below. https://www.nfpa.org/~/media/Files/R...ricalFires.pdf
    This clearly supports the Insurance Companies position.
    The report that you posted did not did not have any data to prove or support any of your contentions.
    I find it bizarre that you believe that fuse panels do not wear out. Any one with even a basic amount of education on electricity understands that all electrical equipment deteriorates with use and eventually wears out.
    The fact that it is becoming difficult to obtain Insurance on a property with a fused panel should be enough reason to inform a client that that may be an issue. The Insurance Companies are denying coverage for a reason. Think about it.
    ......Jim, every thing I read while skimming(admittedly) this voluminous data seems to equate fuses with circuit breakers. In other words, they both serve the same function. If there is a passage supporting your contention that panels utilizing fuses must be summarily replaced, how about leading us to it......Greg
  56. #56
    I would think more of the issues with houses using fuses would be due to age and deterioration from insulation breakdown, not from the fuses themselves. A report on aging electrical systems was recently released but I have not read it or remember the source.
  57. #57
    I never made a convention that panels utilizing fuses must be summarily replaced. So, I cannot support a contention that I never made.
    What a load of misinformation and outright deceit
    Ren -...The panel box is probably beyond its serviceable life ...
    Marshall - Old does count. ..... If a component is nearing or beyond the end of its life expectancy it should be noted. ......
    I think I'll refer to you as Jim Clinton
  58. #58
    I really find this amusing as you are apparently taking the position that a 60 year old ,four branch circuit, fused panel box is OK.
    No Jim
    My position is that you are an idiot and a fool. You misinform and deceive whenever it suits your views. Your goal is not to educate or clarify, it is to irritate and contradict.
    We have seen others like you on this forum. They left, and in time, you will also.
    See Jim, you have no place here, at least not as you have been.
    But all of us must suffer your foolishness until you have gotten your jollies and move on to annoy some other forum.
    PS I'll bet money this is not the first time you were asked to leave a forum.
  59. #59
    No Jim
    Breathe in ... breathe out ... breathe in ... breathe out ...
    Remember: Don't feed the alligators, the bears, or especially the Troll ...
    JA wrote in part:
    Yes I will continue to believe in my research, experience, and I will continue to advise my clients accordingly when it comes to issues such as this, and what there wants and needs will be with their purchase. If I see that the panel is in good condition I am not automatically going to condemn unless there are other mitigating circumstances. Simply based on age is only one determining factor, not the determining factor.
    I'll tell you what, please do not infer that my inspection methods or knowledge are inferior to yours, this is the second time you have done so. If you want to start with that sort of crap find another forum.
    Given your licence suspension with your state licencing board you should refrain from lecturing. I can only imagine what you are under suspension for.
  61. #61
    Jerry
    Do you remember how Ernest killed the Troll? (Ernest Sacred Stupid)
    It was unconditional love.
    Well, this was unconditional tough love.
  62. #62
    Jerry
    I thought it was by tossing down a hand grenade and blowing the bridge up, causing the Troll to become homeless, and, being homeless, the Troll wandered around in a daze until the Troll succumbed to exhaustion ... now that is tough love.
    Oh, so I take it, you don't remember "Earnest Scared Stupid"?
  64. #64
    Nope, never watched any of those Earnest movies.
    Ernest Kisses Boogerlips - YouTube
