    Default check valve on condensate line
    This can't be right. I know the condensate line shouldn't be plumbed directly into the sewer pipe. I mean the check valve.
    Default Re: check valve on condensate line
    You are correct.
    That is wrong.
    Should be indirect. IE Air gap.
    Jul 2007
    No air gap at unit ?
    - - - Updated - - -
