    Nov 2009
    St Paul, MN
    Default Ceiling mounted radiant heat panel
    It's been a week full of oddities for me. Floor drain in the sump pit and now an electric heat panel mounted over the bed. Never seen one before. Are they common anywhere?
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    New Mexico
    Default Re: Ceiling mounted radiant heat panel
    I run across it once in a while, but I wouldn't say it was common. Maybe once a year here on houses built in mid 70's.
    Matt Bezanson's Avatar
    Matt Bezanson Guest
    This is the first time I've seen one built into the house, but in the 70's you could buy these at Kmart. They radiate infrared, so they tend to heat bodies (and other watery objects) more than air. People would use them to be comfortable when the main thermostat was turned way down. Seemed like a great idea at the time.
    Utah
    Properly installed these still make great sense. If your primary heat source is electric these little babies allow for some very specific and efficient spot heating. However in most places (all places that I know of) natural gas and even propane is still less costly than electricity for heating.
    Aug 2013
    MICHIGAN
    They are great for bathrooms to warm a body during bath/shower time during the heating season. Combine with a 15 or 30 minute timer to minimize energy use.
