Results 1 to 11 of 11
Thread: AC SEER
    Baton Rouge, La.
    Default AC SEER
    Can anyone tell me the SEER rating of a Tappan condensing unit, Model# FS3BA048KA? I'm thinking 13 SEER but I don't want to be wrong.
    Jim
    Default Re: AC SEER
    James,
    I usually do not give SEER # in report as there are many things that can affect the actual output.
    Tappan became SJC Corp. 1979(FrigKing Tappan) sold Janitrol line to Goodman.
    Tappan name revived 1998 by Nordyne.
    Lewis Capaul's Avatar
    Lewis Capaul Guest
    Default Re: AC SEER
    Quote Originally Posted by James Bohac View Post
    Jim
    The closet I can find is model number S3BA-048K manufactured in 98 and 99, 11 SEER, 45500 BTUH
    If it is a Nordyne as Billy suggests, it was manufactured in 96', same specs, same model number, without the "F"
    Lew
    Default Re: AC SEER
    I would be *V-E-R-Y* cautious about stating the SEER of something.
    Unless that is a package unit, a mis-match with the interior unit will change the SEER, and there you are stating it is one things, then along comes an HVAC tech who says 'not with that air handler unit, it is not that SEER', and your next phone call is from your client stating that you need to replace the AHU to attain the SEER rating you said it had.
    *I* would not want to go there (and I never did).
    Default Re: AC SEER
    Quote Originally Posted by Lewis Capaul View Post
    Lewis
    Lewis,
    Nordyne !998 on,as they bought the Tappan rights from I think from Westinghouse.
    Kevin Barre's Avatar
    Kevin Barre Guest
    Default Re: AC SEER
    Jim
    James--
    You don't actually state that you are passing this info to the buyer, but if you are, I agree with Jerry. For a system to perform at the expected SEER, the components must be a "matched" set. Unless you want to contact each mfr or go to their sites and wade through their compatibility charts, I would stay away from stating SEER info in my report. I see some generic coils used with new condensing units expected to produce a 13 SEER when used with the proper evap coil. Am I going to guarantee that? No way!
    FWIW, both Tappan and Frigidaire, (and Westinghouse if I remember correctly) are all Nordyne brands now. Generally used for the replacement market, but occasionally found in new construction.
    Nolan Kienitz's Avatar
    Nolan Kienitz Guest
    Default Re: AC SEER
    Jim,
    Stay as far away from stating "anything" to do with a SEER rating to a client. Unless you are a licensed HVAC technician and know all the in/outs related to such ratings you will be getting onto serious thin ice.
    As noted above units have to be matched and there is a lot more than just that which goes into the SEER calculations.
    The ratings are "factory - test environments" and seldom if ever does such a condition appear in actual use.
    Stay safe ... stay well away from SEER rating quotations, etc.
    Tell your client to contact a qualified / reputible and licensed HVAC technician to get such data.
    Lewis Capaul Guest
    Default Re: AC SEER
    Lewis,
    Billy, You're probably right but the Carrier Blue book shows Tappan's of that model number manufactured in 98' and 99', and as a Nordyne in 96'. I'm not a HVAC guy, I can only use the references available.
    Lew
    Default Re: AC SEER
    Yep, at most ... *MOST* ... take a photo of the yellow label which is still on there (if it is) and, under the photo, say 'that yellow label states that it is a 13 SEER unit'.
    That means *YOU* are *NOT* saying 'it is', *YOU* are *just reporting what the label states*.
    But I would not even do that, if the yellow label was still on it, I would take my client out there and show it to them and let them read it if they were asking about it (if they were not asking about it, I would not even do that).
    Mum's the word, zip it up tight.
    Default Re: AC SEER
    Lewis,
    I'm saying you are right sense Nordyne could not manufacture Tappan brand prior to 1998.
    Baton Rouge, La.
    Default Re: AC SEER
    I appreciate the advice about SEER. I have never reported the SEER in the past however my client was asking. Home is four years old and I did explain that units must be matched properly to achieve the listed SEER.
    Clients get fooled by the " High Efficiency " plate on the exterior of some units.
    James
