Results 1 to 33 of 33
Thread: 6,000 Hot Tub on Balcony
04-09-2014, 06:57 PM #1
04-09-2014, 07:24 PM #2
Re: 6,000 Hot Tub on Balcony
04-09-2014, 07:34 PM #3
How did you determine it weighs 6000 pounds?
04-10-2014, 03:22 AM #4
04-10-2014, 03:51 AM #5
Jack, your intuition was correct. The deck was built as a deck to support people. Hot Tubs need their own support designed separate from the deck design.
04-10-2014, 08:27 AM #6
This says the concentrated load is applied to center of stair tread /20 sq in.
Not 64 sq ft of a structure.( what additional supports are under this load?)
*Home owner info may not be completely accurate.
** not that complicated to me ( Get a Structural Engineer to sign off.)
04-10-2014, 08:40 AM #7
04-10-2014, 09:03 AM #8
Bottom line - see below.
We have no technical information as to the structure or the integrity of the connections to the building. Nothing to say it will be OK, plenty to say it will not be OK.
Doing the math to prove otherwise is just irresponsible obfustication, IMO.
Bottom line - a 3-ton hot tub on a balcony which was not specifically designed for that load is a terrible idea, which could have life-threatening consequences.
04-10-2014, 09:59 AM #9
04-10-2014, 10:23 AM #10
04-10-2014, 10:34 AM #11
04-10-2014, 11:37 AM #12
04-10-2014, 11:46 AM #13
Did he go somewhere?
Upstairs at Graceland pictures, Elvis' bedroom, Elvis' bathroom
04-10-2014, 06:44 PM #14
You cannot look at the total design load for the balcony and compare it to the load on the reduced footprint of the hot tub. To properly calculate the effect on the balcony you would need to know the framing layout and the placement of the hot tub. Without all the information you cannot say it looks ok.
04-10-2014, 06:50 PM #15
Not knowing how the deck was built and not knowing how the 60#/sf was calculated with a hot tub at 6,000lb at 64 sf surface yields something like a load of 93lb/sf so
what is the argument??? The hot tub should be replaced with a SUV?
04-10-2014, 07:10 PM #16
04-10-2014, 08:45 PM #17
I saw a deck today that was way overbuilt, four 8x8 posts on concrete piers, strong enough to support several tons I'm sure. But .... my 167 lbs can get it rocking. There's only one small diagonal support on the one post.
Get 3 tons of water rocking and see what that can do to those posts. They be floppin like a catfish on a pole.
04-11-2014, 05:46 AM #18
04-11-2014, 02:45 PM #19
04-12-2014, 12:57 PM #20
Jack,
The attached diagram shows the basic method used to determine if a deck can support any load above the basic 10 psf dead load and 40 psf live load prescribed by code. The hot tub in your photo will have an impact on the section of deck depicted in the diagram. If the added load, in this case the hot tub, was supported on blocks or four legs that would concentrate the load in a very small area, then you would start by checking the deck boards to see if they could carry the concentrated load. Most hot tubs spread the load over the whole bottom area, so you can skip #1.
Start by placing 10 psf dead load over Area 1 & 2 plus 40 psf live load over Area 1 & 2, then add the weight of the hot tub over the foot print of the tub in Area 1. Check the joists under the hot tub, if they pass, check the joist hangers on the tub side of beam AB and beam CD. Next check the design of beams AB & CD. Next check the load capacity of the post connections at A, B, C & D. Finish up by checking the load capacity of posts A, B, C & D, followed by the footing under each post.
The load carrying capacity will be limited to the weakest link in the load path from the deck boards down to the footings.
04-12-2014, 01:54 PM #21
Sorry Jack, I was responding to a hot tub issued in another message board.
I would need to see a photo, I have never seen a 16' cantilevered balcony on a residential structure. Was it a propped cantilevered or just a tall deck with posts and no stairs?
04-13-2014, 06:51 AM #22
Was wondering how long it would take to get to the "balcony" vs "deck without stair" discussion would crop up.
Have to love all the assumptions that are being made based on so little information with the added assumption that the info from the OP is correct in every aspect. It may be like the two blind guys on either end of an elephant describing what it is.
Math like the internet never lies and Bees can't fly.
04-13-2014, 04:54 PM #23
04-13-2014, 06:19 PM #24
04-14-2014, 03:42 AM #25
Re: 6,000 lb Hot Tub on Balcony
Jack, do you have pictures from the balcony deck and one looking up to see the supporting framing, or can you easily get them? This is essential, as you can see, in answering your question. Also, is the balcony first or second floor? Are there any supports under the balcony? Pictures of this would also be helpful.
04-14-2014, 07:06 AM #26
Lots of commentary for a simple answer. As a generalist, you need to know when to call for an evaluation by a structural engineer. As a HI, you can overstep your expertise and role by trying to factor all the variables and math on this.
Tub parties with guns..........what can go wrong? Count me in...........as long as an engineer has deemed the balcony deck safe to hold the load cause I am Mr. Safety.
04-14-2014, 06:02 PM #27
04-14-2014, 06:14 PM #28
04-15-2014, 10:02 AM #29
Jim,
Need to add in the 8 linebackers and 4 cases of beer and maybe a few Cheer Leaders
and some other
friends. Oh, don't forget the music and dancing.
04-15-2014, 11:26 AM #30
Jim,
OP stated the ( contested balcony / deck ) was rated @60psf. not 100 psf.
*the attachment says if the balcony is over 100 sf them must be rated 100pst. so automatic fail based on our limited information.
Mark Reinmiller could give us a definite answer if he were provided the actual information.
We as in you/I could not.
*your stack barrel looks like a 1960's Hardware Company Brand gun someone unqualified put a recoil pad on.
06-16-2014, 12:17 PM #31
Any deck with a hot tub should be specifically designed to carry that heavy of a load under the tub itself. I would recommend a structural engineer take a look at it and make a recommendation as to how to reinforce the deck to hold the weight otherwise the tub should be moved elsewhere.
Even an under constructed deck may hold the tub just fine but then again it may not. Water is about 10 pounds per gallon plus the weight of the tub, a previous job of mine was working in the aquarium industry and I have seen very heavy aquariums held up by floor joist that should never have held them but ive also seen catastrophes where they fell through the floor. Always better safe than sorry, fix the deck.
Absolute Home Inspection Services, LLC
Saint Louis Area Home Inspections
www.absolutehomeinspectionservices.com
06-16-2014, 01:23 PM #32
06-16-2014, 06:35 PM #33
Typical 4-5 person hot tubs are around 500 gallons and in another 250 lbs for the weight of the unit and you have right at 6,000 lbs. Water weighs around 8lbs per gallon.
Add in the weight 4 adults will push it up another 600 to 800 lbs or better!
I have seen many hot tubs on decks of cabins in the Smokies and I wonder every time with some I see why they have not collapsed the deck.
