    Clay White's Avatar
    Clay White Guest
    Default Plumbing vent, attic opening
    Default Re: Plumbing vent, attic opening
    Was it still resting on those nails too, or was it down on the trim and you had to maneuver over the nails too?
    Yes, both (the PVC and the nails) interfere with the attic access hatch covers removal and replacement, which could lead to breaking the drywall cover, and also reduces the opening size to that which is below the required minimum (if it does, can't tell from the photo).
    Richard Rushing's Avatar
    Richard Rushing Guest
    Clay,
    I always comment on any obstruction over the scuttle access. Especially if it would or could be damaged by a person entering the attic.
    rr
    Nope!
    Tom Munds's Avatar
    Tom Munds Guest
    I agree with Richard. Write it .
