    May 2014
    south carolina
    Default Who would you recommend following up on this brick issue
    real issue with brick on the last couple of inspections and just tying to check what everyone else is doing?
    Capistrano Beach, CA
    Default
    Hello Greg Clemmons,
    Welcome aboard. Enjoy your visit here at InspectionNews and if there is anything I can help you with just let me know.
    In the upper left of the page there is a gift for business owners and one for home buyers, sellers or DIYers. This gift is from me to you. I hope you like it.
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Default Re: Who would you recommend following up on this brick issue
    Undetermined cause but suspect the brick shelf broke.
    Lansdale, PA
    I'm assuming there is a block or concrete foundation behind the brick. I would suspect the crack is due to differential expansion between the different materials due to changes in moisture or temperature.
    I didn't think of that. That's why your an engineer and I'm "just an inspector".
    Cracking due to downspout drainage next to the home.
