    St. Louis, Mo. area.
    Default Unknown Pipe Clamp.
    Hi all!
    This is the interior side of a frost proof hose bibb installation, but this clamp widget has me scratching my head. Can someone enlighten me as to what and why?
    Thanks a lot for your help with this.
    Default Re: Unknown Pipe Clamp.
    Quote Originally Posted by Michael Chambers View Post
    Hi all!
    The clamp is there to stop a pinhole water leak.
    Agreed, it's a repair clamp.
    I suspect there are or will be other pin hole leaks.
    I think so also. I tried to find the thread where we had discussion about pinhole leaks in copper water lines but could not find it.
    Sep 2010
    NY Finger Lakes Area
    Hi all!
    ......the why is that someone did not disconnect a hose during freezing weather and the bib froze far enough in towards the stop to rupture the faucet barrel/housing. I'm sure there will be no further issues, providing the clamp is secure........Greg
    Sep 2007
    Fredericksburg, VA
    Quote Originally Posted by Gregory Booth View Post
    I'm guilty of doing something like that back in the late 70's. Both frostless sill cocks froze and split. When I turned on water outside in the Spring there was, of course, a flood in the crawl space. No fancy clamps for me! I don't now if they even existed then. I cut a piece of copper pipe to make partial wrap to go over the splits, applied at lot of silicone and 3 worm clamps on each split. Never had another leak from them. Lucky I guess.
    Stu, Fredericksburg VA
