Results 1 to 13 of 13
    Aug 2011
    Default Flex gas line connection
    I thought there had been a previous thread about this "non standard' installation, but I couldn't find it. Is this allowed?
    North Central Texas
    Default Re: Flex gas line connection
    Where exactly is the appliance for the appliance connector?
    Texas Inspector
    http://www.texasinspector.com
    Jan 2011
    Utah
    According to the industry, CSS can be used where ever steel pipe would be used.
    The Benefits of Corrugated Stainless Steel Tubing (CSST) and CSST Installation & Safety Information
    North Central Texas
    Quote Originally Posted by Jimmy Roberts View Post
    Yes, but that is not a picture of CSST . . .
    Texas Inspector
    Aug 2011
    That T and valve off it runs to a gas conversion fireplace. The flex continues the gas line to the furnace and water heater.
    But, as Aaron stated, that's an appliance connector, not CSST.
    North Central Texas
    The appliance connector is intended to be installed only between the gas supply piping and the appliance itself. it should be used as a splice between two sections of threaded steel gas supply piping. This triggers IRC 102.4.
    Texas Inspector
    Welcome back, Aaron,
    "it should be used as a splice between two sections of threaded steel gas supply piping"
    I believe you are missing a "not" in there.
    North Central Texas
    Not a not, huh? Damn! Sorry! Multitasking strikes again . . .
    Texas Inspector
    Why is this product not treated and require the same protection as CSST which is heavier grade.
    Seems ridiculous to bond CSST when this is downwind of it.
    Just thought after looking at a few thousand of them.
    It's the distance that CSST covers which increases its probability of a lighting strike. All of the appliance connectors I have seen are normally less than 24" and are connected to black pipe.
    An "appliance connector" means it must be within 6 feet of the appliance and connected to the appliance. See ANSI Z21.24 vs. LC1 for CSST, which is "piping" and not a "connector". Read the listed instructions for each. The application in the photo is improper. Flexible appliance connectors cannot exceed 3ft except for dryers and ranges, which can be up to 6ft. in order to pull the appliance out. You can NOT splice flexible appliance connectors the way you can CSST. The mechanical couplings with CSST are made up on site for each connection. The couplings on flexible appliance connectors are made in a factory supervised by a listing agency. Two entirely separate products.
    North Central Texas
    I agree that CSST and gas appliance connectors are separate entities, each with its own set of manufacturer's installation instructions and other industry standards. That said, they are very similar in that they consist of thin-walled flexible stainless steel tubing. The subrogation attorneys apparently do not differentiate: : Angela Hahn : Subrogation & Recovery Law Blog
    Texas Inspector
