Results 1 to 16 of 16
Thread: critter device
07-09-2014, 11:53 AM #1
critter device
This appears to be some kind of one-way critter device. Anyone ever seen anything like this? Is it home-made or do pros install these?
07-09-2014, 12:31 PM #2
Re: critter device
French fry basket ...
Looks more like an exit and no re-entry device.
07-09-2014, 12:40 PM #3
Re: critter device
07-09-2014, 01:33 PM #4
Re: critter device
that's a broker basket
07-09-2014, 01:38 PM #5
Re: critter device
I haven't seen one before, however, based on what looks to be a label on the top of the device, I am guessing that it is a manufactured unit.
Let those rodents out and keep them from coming back in, better than bait/poison and having them die in the attic and start stinking.
07-09-2014, 03:18 PM #6
Re: critter device
A few years ago I had a rental property in Atlanta that had squirrels in the attic.
Saw an advertisement that said "I can get rid of squirrels in your attic, guarantied. No poison, no traps. " So I called the number and told him to do it. He came out and put a cat in the attic. Cat chases out the squirrels, and he put screen over holes.
I didn't know if I should be amazed at his ingenuity, or angry that I was duped.
Paid him $250. Squirrels are gone.
07-09-2014, 03:18 PM #7
Re: critter device
....Home fashioned bat cage, though typically bats enter and egress at the same access point. Could be to capture any orphaned young who haven't left their roost yet.
07-09-2014, 03:34 PM #8
Re: critter device
It ain't catching anything with the door tripped shut.
A couple of those high frequency noise makers that look like transistor radios would probably work better than trapping one animal with that goofy arrangement.
I am picturing the guy on the ladder with a screwdriver and an angry wolverine in the cage.
OK, I see now, the end of the 'cage' is open to let them out so they can find a new way in.
07-09-2014, 04:08 PM #9
Re: critter device
Not supposed to catch anything.
Critter trying to get in can't open the door ... critter going out steps out, door closes behind it - leaving that critter two choices: a) jump; b) stay there and die ... I suspect that any self-respecting critter is going to choose a) ...
07-09-2014, 04:30 PM #10
07-09-2014, 06:51 PM #11
Re: critter device
07-09-2014, 07:37 PM #12
07-10-2014, 03:39 AM #13
Re: critter device
It will work. Animal will push past door.
Wish I had picture of one I made up for a friend with a squirrel invasion in attic. I fought with the squirrels for several days before I caught all of them and took them for a road trip. Found that just chasing them out of attic was a temp condition. They would come back. I put screening on interior of wood louvered end gable vent. The squirrels chewed out all of the wood louvers and ripped out the screening.
07-10-2014, 06:59 AM #14
07-14-2014, 04:06 AM #15
07-17-2014, 05:57 AM #16
Re: critter device
Great device, but once the critters are gone it should have been removed and the area properly repaired. Also it is very important to find the secondary entry/exit. Most animals will make a secondary.
I built a much less elaborate one to get a raccoon and her kits out of an attic. Closed up two entries and left one open. Made LOTS of crazy noise (firecrackers in tin cans etc), set up traps int eh attic (most raccoons in the area have been trapped and wont go in one, they know they are being targeted when a trap arrives. They were gone the next day and I sealed the area properly.
Some crazy "professional" trapper had charged the people 150 and didnt get them out then wanted 1500, said he had to kill them then tear out structure to get the bodies. Took me 2 hours total plus two trips driving there.
