Results 1 to 13 of 13
    Cory Bates's Avatar
    Cory Bates Guest
    Default register in garage
    I am having a bad day and can't remember is it acceptable to have a heat register vent directly into the garage?
    Mesa, Arizona
    Default Re: register in garage
    No, not into garage if origin is home
    Jeff Moore AZ Cert#49250
    Level II Thermographer
    http:www.quantumhomeinspections.com
    Cory Bates's Avatar
    Cory Bates Guest
    So this is not okay?
    Quote Originally Posted by Cory Bates View Post
    Cory,
    If it's combustion air for the furnace OK.
    Not OK.
    *doesn't matter if it's a supply or return. Possible for car exhaust to enter the conditioned
    That does not look like combustion air.
    It looks like a return, and no its not allowed.
    Don't forget the sediment trap also.
    Nov 2009
    St Paul, MN
    Is it just me? Isn't that a downdraft furnace in the garage? Doesn't appear to be ductwork shared with the house. Looks like the furnace sits above the register. Cover for the furnace is in the lower right corner of the picture. Looks fine to me.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    It looks like a downdraft furnace with a register open to the garage but an establishing shot would be helpful.
    Any conditioned air duct is not allowed to be open to the garage.
    Or an updraft split system with a Goofy combustion air draw.
    Is that duct board around the unit just there for looks (ugly looks, but still for looks) or is that the supply (or return) plenum?
    If that is supply or return plenum, then the entire thing leaking air to the garage or sucking air from the garage.
    GARAGE DUCT INSTAllATION
    R302.5.2 Duct penetration. Ducts in the garage and ducts penetrating the walls or ceilings separating the dwelling from the garage
    shall be constructed of a minimum No. 26 gage (0.48 mm) sheet steel or other approved material and shall have no openings into the garage.
    Oct 2011
    california
    No only if it has all solid 26 gage sheet metal all the way back to the unit to maintain the fire envelope
    no only if 26 gage metal ducting to maintain fire envelope
    Quote Originally Posted by frazier jeffery View Post
    Not even then.
    The question was not about "duct work" in the garage, the question was about a supply register open to the garage.
    NO supplies or intakes (returns) in a garage for a unit/system which is for the living space ... NONE.
