Results 1 to 13 of 13
Thread: Wet Walls
    Sherrill Jeffcoat's Avatar
    Sherrill Jeffcoat Guest
    Default Wet Walls
    I just inspected a house with interior sheetrock walls that appeared completely dry but when I checked them with a moisture meter, some of the walls pegged my moisture meter and other interior walls indicated normal moisture. All of the walls looked the same. No moisture stains except inside the garage. The lady of the house previously complained of moisture intrusion inside the garage. She did have a roof leak that damaged a garage wall. So, to be safe, I checked all of the interior walls and found some that pegged out my Tramex non-invasive moisture meter and others with normal moisture. I checked to make sure there were no metal wall studs. I also checked the attic of moisture intrusion and there were none. I do not have an explanation of this. In my 13 years of inspecting, I have never see this condition. Anyone seen this before.
    Sherrill Jeffcoat
    Northern Indiana
    Default Re: Wet Walls
    Quote Originally Posted by Sherrill Jeffcoat View Post
    Sherrill Jeffcoat
    Probably caused by excessive EMI.
    If pegging the moisture meter only happened on exterior walls, I would say that it could be foil faced insulation, but ... you said interior walls a few times and I doubt the interior walls would be insulated, and if they were insulated, the insulation would be for sound so they would have used batt insulation.
    I inspected a house once years ago which, when I walked in, smelled of mold (mould).
    The builder had framed many of the interior walls without top plates - the studs extended up to and were nailed to the ceiling joists. This left the stud cavities open to the attic.
    Not only was that a big framing no-no (the stud cavities were not fireblocked at the ceiling), but the moist and humid air in South Florida (Coral Gables) was down into the stud cavities ... the inside surfaces of the drywall were*covered with mold.
    The seller didn't smell anything, my client didn't either, but the odor was so strong the agent and I had to keep going outside for fresh air.
    As I recall, there were many other things wrong with that house too. I believe the client bought it anyway as it was a large house on a large lot in a desirable area in Coral Gables (as though there are "undesirable" areas in Coral Gables).
    Sherrill,
    My SWAG is a Major Water Event. Burst Pipe, W.H. ( check moisture levels low and high on the walls.)
    Disgruntled Mortgage Holder plugged drains and ran the water ?
    Pull back some carpet and check for moisture.
    This is a good time to have a pin-probe moisture meter, to verify the results of the sub-surface scan.
    Either the walls were wet/damp, or they weren't; no way to confirm that remotely. Recent burst pipe, interior flood or large leak, etc. Or anomalous readings that aren't moisture.
    Dom.
    I know of entire subdivision that the builder used a silver Mylar wrap on all exterior walls and then the drywall. Every single time I have tried to check moisture, it pegs every single non invasive moisture meter I have.
    Did the home have A/C? When was the last time it rained?
    What are you located, this helps big time..
    I agree with the others. I always use the contact pins to backup the findings of my meter when scan mode indicates elevated levels. Metal will throw moisture meter readings off.
    Must be out working ... or maybe his hyperspace connection is down?
    Been out working.... just go in. thanks for all the responses. Again, these were interior walls. Some of the walls would show high moisture readings and others with no moisture / normal moisture. I even checked the next door neighbors interior walls and they were ok. To be more specific, 3 or the 4 the master bedroom walls show high readings while the other did not.
    I am located in Alabama. There must be some kind of Mylar wrap on the interior of the walls. Yes, the A/C was on and operating properly. We have had a very wet summer in Alabama, so that could have contributed some way.
    I am going back today and look for a top plate like Jerry mentioned.
    Sherrill Jeffcoat
    Sherrill Jeffcoat
    I have seen this condition several times. It has always been an older home, built prior to central air conditioning being the standard. All were brick veneer on vented crawlspace with pier and curtain foundation walls. The walls in this era were not well insulated and warm humid air could enter the gap between the rim joist and the brick. After installing central air the cold interior walls condensed moisture on the minimal insulation, which then sagged from the weight, allowing the moisture to condense on the back side of the drywall or wood panel. Also found this condition at walls around fireplaces, wet walls, and chases at the interior of the home.
    As has already been posted, you need to have a pin meter in addition to a noninvasive meter. The noninvasive meters measure in a loop from one pad to the other and about 1.5 inches deep so they measure more than what you see.
    http://www.jjeffzehnder.com/
    Jun 2008
    If it's an older house the interior walls may be of plaster construction. Plaster can register as wet when it really is not. Perhaps the exterior walls had been stripped and redone with gypsum to gain access to add insulation and that's why they don't indicate moisture.
