Thread: sewer plug of sorts??
09-10-2014, 08:09 PM #1
Hello All
I have never seen a plug/ blockage for an unused sewer line. Does anybody know what it is?
09-10-2014, 08:31 PM #2
Re: sewer plug of sorts??
It's a temporary test cap that needs broke out and removed. A threaded fitting with clean-out cap should be installed. I see these in the crawlspace quite often, some times I find them left on at the roof vent pipes.
09-10-2014, 08:40 PM #3
09-11-2014, 07:47 AM #4
Caps, who needs caps. Looks good to me, (SARCASM) This was the first house yesterday.DSCN3851.jpg
The waste lines were made of PVC, ABS, Cast iron, and Copper.
09-12-2014, 08:58 PM #5
09-18-2014, 09:11 AM #6
09-19-2014, 11:30 AM #7
It is soldered though, which if done well, is sufficient.
the biggest problem visible in the photo is the tee-wye on its back, and the failed branch connection. (pulled right out, with no visible glue signs)
[QUOTE=David Johnston;247922] ... the biggest problem visible in the photo ...
after looking again I see that the cast wye has a rubber (plastic) wired over it for a cap -- also a big problem...
09-19-2014, 08:30 PM #8
[QUOTE=David Johnston;247922]It is soldered though, which if done well, is sufficient.
You are very correct, I noted multiple other plumbing issues under this house.
12-04-2014, 06:42 AM #9
Me thinks Virgina R Hammond might be more than a few individuals. Just look at the two post from it and the different writing styles.... Just saying...
12-04-2014, 07:22 AM #10
