    cory nystul's Avatar
    cory nystul Guest
    Default who needs wood when you have bailing wire
    I found this to odd not to share.
    May 2009
    Washington State
    Default Re: who needs wood when you have bailing wire
    I knew I should've patented that idea !
    Apr 2014
    FL, TX
    Quote Originally Posted by cory nystul View Post
    At the University we had concrete walls in the dorms. I built a book shelf that was hung by bolts in the concrete and 4 chains. this allowed us to not take any floor space for the book shelf (we had vaulted cieling on the top floor of the dorms). There was no other anchor to the walls at all, no ledger etc. Worked excellently and we left it behind along wiht an MC Escher taking up one entire wall (painted on).
    Except for the limiting strength of bailing wire the concept is actually great.
    Jun 2010
    Houston, TX
    Did you find the label on that wire that lists the load rating. It would have probably been pretty small! :>}
    - - - Updated - - -
