Thread: Unkown hole is fake beams
09-13-2014, 11:07 PM #1
I was inspecting an A frame today and found these unknown holes in the beams. The beams are fake but the holes are not any ideas what they might be for? The one in the sheet rock appears to be a nut.
09-14-2014, 11:58 AM #2
Re: Unkown hole is fake beams
Cory,
These McMaster-Carr were probably added by HO to attach or string decorative items.
09-14-2014, 12:50 PM #3
The common name for those is "tee-nuts" and "T-nuts":
- Shop Standard (SAE) Tee Nuts at Lowes.com!
- Tee Nuts - Nuts - Fasteners - Hardware - Tools & HardwareÂ*at The Home Depot
- T-Nuts - Bolt Depot
Unless there is a matching and corresponding hole on the other side so a bolt can be installed through that beam ... I wouldn't hang anything from them as there is nothing to hold them in place (other than a through bolt through the fake beam from the other side).
09-14-2014, 02:18 PM #4
09-14-2014, 05:07 PM #5
Originally Posted by Billy Stephens
They are, or at least one or some are, in drywall - not sure, but I take it as meaning drywall fake beam.
Lightweight decorative items shouldn't pull thought urethane fake beams, would probably pull the fake beams down before the foam allowed a bolt to pull through. At least based on the fake urethane beams I remember from years ago.
09-14-2014, 05:52 PM #6
Yeah Well they don't make Fake Beams like they use too!
Architectural Foam Shapes
09-14-2014, 06:59 PM #7
