Thread: Switch for a dryer booster fan
09-24-2014, 11:08 AM #1
I know there are a lot of opinions on the use of dryer booster fans.
I ran across one in a condo today. The total run of duct was about 35'. Elect dryer.
The booster fan is below the laundry room about 15' from the dryer. It is labeled
as a "Elicent AXC100A" fan.
Two questions: 1) Is this fan even proper for a dryer vent use? Looks like it is not from what I could find.
And 2). It is on a separate wall switch. Must be turned on separate from the dryer. I would think if a booster fan is allowed, it would have to be on an automatic type of switch (maybe a pressure switch) so it always comes on when the dryer is turned on. Comments?
09-24-2014, 11:22 AM #2
Re: Switch for a dryer booster fan
Dryer Exhaust - Fantech
How do dryer exhaust fans work?
When the dryer is on, the patented pressure switch senses positive pressure in the duct and turns on the booster fan for a pre-determined time, at the end of the timer cycle the switch checks for positive pressure in the duct, if there is pressure in the duct the cycle continues.
09-24-2014, 11:32 AM #3
09-24-2014, 11:40 AM #4
Sorry
It looks as though this fan is "proper for this use".
These are suitable for ducted ventilation systems in residential, commercial and industrial applications.
Elicent AXC Centrifugal Inline Fan - Size Options | Universal FansUniversal Fans Store
I was showing that at least some fans do come on automatically.
09-24-2014, 11:53 AM #5
09-24-2014, 11:58 AM #6
I'm only repeating
click on this link:
This is what it says
The AXC TP high performance centrifugal in-line fans are available in 4 sizes from 100mm diameter to 160mm diameter. These are suitable for ducted ventilation systems in residential, commercial and industrial applications.
09-24-2014, 12:05 PM #7
I say that is not proper for this use as those are for ventilation, not dryer ducts.
These dryer booster fans ( Continental Fan - Residential Fans & Air Purification ) have a model number which starts with a "D", for "Dryer"?.
09-24-2014, 12:07 PM #8
09-24-2014, 12:07 PM #9
Reading further it just says venting.
Since there is no mention of an auto-on feature, this fan is likely not a good choice for a dryer duct fan.
09-24-2014, 12:12 PM #10
09-24-2014, 01:09 PM #11
