    Cape Cod, Massachusetts
    Default Service wires in contact with metal downspout
    Here's a picture that is probably familiar to all of us.
    My senses and (my reports) say that this is a potential shock hazard and should be fixed, but I don't have any code reference for this statement.
    What code sections would this fall under as a safety hazard.
    Ken Amelin
    www.midcapehomeinspection.com
    Jul 2010
    Summerville, South Carolina
    Default Re: Service wires in contact with metal downspout
    I've seen many service cables with cracks and splits in them so I would say extremely dangerous.
    Apr 2013
    texas
    Simply "wiring methods". The service entrance conductors are NOT "free from physical damage" and if in direct contact with any metal part, has the potential of energizing that metal part and anything or anyone in contact with or in close proximity of that energized metal part.
    Hope that helps
    Jan 2011
    Utah
    The public utility owns the Service Entrance Cable. It appears one of the phase conductors is on the opposite side of the down spout. The utility would not route the conductors around a down spout, so the down spout was inserted between the conductors. Contact the public utility. They have exclusive jurisdiction to maintain these conductors, and correct this problem.
    May 2010
    No. San Diego Co., CA
    [QUOTE=Jimmy Roberts;248360]The public utility owns the Service Entrance Cable. It appears one of the phase conductors is on the opposite side of the down spout. The utility would not route the conductors around a down spout, so the down spout was inserted between the conductors. Contact the public utility. They have exclusive jurisdiction to maintain these conductors, and correct this problem.[/
    Why not re-locate the downspout and seal the existing gutter outlet, no permit or utility co. involvement. Or extend the mast and weatherhead above the roofline and connection to the meter by the utility co. Permit required. Either way, I agree, a fix is appropriate.
