    Sep 2011
    Bolingbrook, IL
    Default Cutler Hammer Panel
    Hello all
    This is a Cutler Hammer Panel. I'm assuming that these breakers are made for 2 wires.
    100A service
    Atlanta, Georgia
    Default Re: Cutler Hammer Panel
    Then your assumption would be wrong.
    Some CH Classic are listed for use with two conductors.
    Sep 2011
    Bolingbrook, IL
    Can you elaborate
    - - - Updated - - -
    These were listed as Class CTL OH 120 volt 1 pole unit
    Sep 2011
    Bolingbrook, IL
    Hello
    Anything definitive would help
    Lansdale, PA
    I believe the Cutler Hammer breakers listed for two wires have a screw head to hold the wires and small protrusions on each side of the screw to keep the wires from slipping out to the side.
    They are new enough that you can check by going to a big box and looking at the labels on the side of the breakers.
