    Forrest Jones's Avatar
    Forrest Jones Guest
    Default New Member. Question: Any problem with heat tracing exterior, insulated PEX piping?
    I am a new member that has a question about PEX piping and temperatures. Can Pex piping (wrapped with insulation and encased) be used in an exterior environment with heat tracing to prevent freezing? Will the heat tracing get too hot for the Pex? And does anyone know how hot the heat tracing usually get up to? We are planning on using Z-Supply's 5" EZE Flex Silver foam 5 layer system for covering an insulating the hot and cold Pex pipes. The maximum temperature of the hot water line may get up to 200 degrees but will usually just be up to 160 degrees.
    Capistrano Beach, CA
    Default
    Hi Forrest Jones and welcome to InspectionNews!
    I hope you find everything you are looking for on this site.
    If I can help you in any way just let me know.
    If you are a business owner please accept this gift for making your first post: http://www.inspectionreferral.com
    If you are a home buyer, seller or DIYer, this gift is for you: http://www.inspectionnews.net/home-i...als/member.php
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Default Re: New Member. Question: Any problem with heat tracing exterior, insulated PEX pipin
    Heating cable is not to be insulated. It states that right in the instructions.
