    Clay White's Avatar
    Clay White Guest
    David Banks's Avatar
    David Banks Guest
    Default Re: Exterior Outlets, GFCI, Bubble Cover,
    What do you expect from a bubble head.
    Quote Originally Posted by Clay White View Post
    Here is what the builder told me today (an exact quote):
    "Exterior receptacle outlets do not need to be GFCI protected if they have bubble covers".
    Clay,
    Sometimes the best way to get the builder's attention is to agree with him (somewhat ) and say: "You know, I think you may have something there, I believe there is an exception which does allow no not having GFCI protection when bubble covers are installed, but ... the bubble cover is only one part of that exception - the exception says *IF ALL THE FOLLOWING ARE NET*, and item 1) is using a "bubble cover", then there is item 2) DISCONNECT ALL ELECTRICAL POWER TO THE STRUCTURE ... do both, and, yeah, no GFCI protection is needed there."
    Richard Rushing's Avatar
    Richard Rushing Guest
    here is the headbanger
